Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
1.8 zetec head mods
Old Apr 18, 2012 | 05:33 PM
keyz's Avatar
keyz
Arse
Default 1.8 zetec head mods
HI guys..
If i get a Big valve spec done to my head + a set of cams to match Do you think that it would run ok. i.e would it be to much for the bog standard ecu to manage.. ?
Granted i know i wont get the full potential out the head due to injectors and no turbo etc.. i just want to know if it will work a ok seeing as its not a normal thing to get done then run it on standard managment - well at least till i get a MS ecu.
Old Apr 22, 2012 | 10:33 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
yeah should do no probs, has long has the cams not to radical.
i have a area 6 zetec ported head off of my old zetec but its standard valve sizes
kevin36
Sep 9, 2015 11:12 AM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
little bram
Sep 7, 2015 11:59 AM
