oil level problem cosworth engine
Old Apr 18, 2012 | 04:30 PM
sierrafun's Avatar
sierrafun
Default oil level problem cosworth engine
hello i see oil level comes lower time by time .i did 25000 miles from my last built .and i see that after 300 miles the level oil is down for 500 ml ..what you think???? is the cylinder oval shape from bad programm the turbo is new built from cr turbos recently ..mahle pistons standar 205 block another options ? write what you think
Old Apr 18, 2012 | 09:36 PM
wolf cosworth's Avatar
wolf cosworth
If in doubt ! Flat out !
Hi ,
on the inlet there is a return valve above the standard oil seperator make sure this works correctly otherwise you will use more oil then normally ...
Other thing I believe in the manual for the cosworth if under good driving I mean the car can use upto 1 liter 1000km but I leave the experts to answer that here ...
gr,Steven
Old Apr 18, 2012 | 10:05 PM
botters's Avatar
botters
competant bodger
some people say a litre of oil in a 1000miles is acceptable but ,mine never uses any so it all depends on the engine, as above some may use 1 litre in a 1000 miles some may not
i personally have never topped up in 2500 miles (and no it isnt filling back up with petrol before you ask lol as fuelling is spot on lol)
Old Apr 20, 2012 | 09:36 AM
sierrafun's Avatar
sierrafun
Originally Posted by wolf cosworth
Hi ,
gr,Steven
thanks mate i ckeked that is perfect
Old Apr 20, 2012 | 09:37 AM
sierrafun's Avatar
sierrafun
what about the forged pistons ? do they burn oli after 20000 miles ?
Old Apr 20, 2012 | 10:10 AM
wolf cosworth
As long as when you ran your engine in with mineral oil and then afterwards change to synthetic oil I donnot think your engine under normal circumstances is using this much oil from my expierence unless something else is creating this.
my saphire stage 2 was even after complete rebuild still using oil due to not a good breather system ( open vent ) ... and a friend of mine on his stage 1 is putting so much oil in we even wonder if service is needed yearly ...
But my standard 3 door now is not using any as far as I know ( should not say this to loud ... )
As long as your engine is running OK and set up correctly do you want to opne up the car again and not find anything with that money you can buy some liters of oil to run it anyhow , just make sure you keep checking on a regarly base.
Steven
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
mattman1234
24
Aug 1, 2015 11:46 AM
