Ford KA Discuss your Ford KA here!
DTC help
Old Apr 18, 2012 | 10:10 AM
cutez877's Avatar
cutez877
Default DTC help
hi
i have recently bought a diagnostics plug and software to get to the bottom of my engine light issue and was woundering if anyone could point me in the right direction what to check etc i have DTC's p1632 p1000 p0306
thanks everyone
Old Apr 18, 2012 | 10:40 AM
oldford's Avatar
oldford
P1000 is just a warning, so not a direct problem.
P0306 is a misfire on cylinder 6. But 6 cylinders on a KA?
P1632 is a Smart Alternator Faults Sensor / Circuit.
Old Apr 18, 2012 | 10:46 AM
cutez877's Avatar
cutez877
Originally Posted by oldford
P0306 is a misfire on cylinder 6. But 6 cylinders on a KA?.
That's what I thought but why would it come up with it? I cleared that fault code but came straight back up again don't understand it, it does misfire when ur at low revs
Old Apr 18, 2012 | 11:08 AM
oldford's Avatar
oldford
So, which cylinder misfires is a mystery. Maybe try a different scanner.
Otherwise check for air leaks and check injector spray patterns.
Old Apr 18, 2012 | 11:54 AM
Shonky's Avatar
Shonky
V6 Ka of Love
I have a 6 cylinder ka!
The ka has no method of detecting which cylinder the misfire is happening on, start with air leaks as mentioned (google how to find vacuum leak), check leads, check spark plugs, change coilpack
Old Apr 18, 2012 | 01:32 PM
cutez877's Avatar
cutez877
Thank u for all ur help guys gonna have a look at it tomorrow
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Ilovemyfez
Apr 25, 2005 02:20 PM
