Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Fiesta 1.25 Zetec woes
Old Apr 11, 2012 | 04:20 PM
galahad's Avatar
galahad
Default Fiesta 1.25 Zetec woes
Had this before, but got bored of the car so I ended up binning it.
Got another T plate Fiesta 1.25 Zetec today, and its got the same problem I had before, but this one is a little too pretty to be scrapping.
Basically, it won't rev past 4000rpm, its obviously in some kind of limp mode, but theres no engine management light on to notify a fault.
Replaced air flow meter and that altered nothing, disconnected catalytic converter, that did nothing, cleaned out the throttle body and there was no difference.
Revs cleanly and smoothly upto 4000rpm and then won't get past as if its hit the rev limiter early, so coilpack isn't suspect at the moment.
Its a T plate 1.25 Zetec Automatic, i'm sure this must be a common problem, any ideas anyone?
Old Apr 12, 2012 | 09:33 AM
galahad's Avatar
galahad
anyone?
Old Aug 2, 2013 | 12:09 AM
ajuk's Avatar
ajuk
Clean the Mass Airflow Sensor.
Old Jan 15, 2014 | 07:29 PM
George_77's Avatar
George_77
Diagnose the ecu for faults probably a faulty cam sensor....
Mark_
40
Oct 2, 2015 04:40 PM
SMILER258
Sep 28, 2015 09:04 AM
Marv888
Sep 26, 2015 03:44 PM
