Rs turbo head the same as any other 1.6 cvh head?
Old Apr 9, 2012 | 04:07 PM
lee2cossies's Avatar
lee2cossies
Default Rs turbo head the same as any other 1.6 cvh head?
Have a cvh head here not sure what it came off other than I know it's a 1.6 cvh! Are they the same as Rs turbo head? Or is the turbo head different in any way?
Old Apr 9, 2012 | 07:34 PM
project rs's Avatar
project rs
depending what it come of could be a leanburn head
Old Apr 9, 2012 | 10:38 PM
lee2cossies
Not really sure! Just bought it and not sure what model it came off. How do I tell if it's lean burn or not?
Old Apr 9, 2012 | 11:15 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
I think the heads are interchangeable but rs turbo valves are different and obviously the cam. Then again does the efi head have different shaped inlet ports??
Old Apr 10, 2012 | 06:33 AM
Rick's Avatar
Rick
Any injection head.
Old Apr 10, 2012 | 09:42 PM
mentalasanything's Avatar
mentalasanything
IIRC MFi RS Turbo heads are unique due to the composition of the valves. But everything else is shared with non turbo MFi heads.
All 1.6 EFi heads are the same wether it be an XR3i, XR2i, FRST, 1.6i etc.
Lee
Old Apr 10, 2012 | 09:51 PM
Brendan's Avatar
Brendan
struggling with reality
I thought it was the pistons that differed in the Turbo'd vresions! the only difference otherwise is the inlet ports which are different on the fiesta RST to the escort RST due to the inlet manifolds being different! - I think!
Old Apr 10, 2012 | 09:56 PM
PhilCook's Avatar
PhilCook
Are you sure? I am sure I have seen some where there is more meat around the valves
Old Apr 11, 2012 | 10:14 AM
Rogeyboy's Avatar
Rogeyboy
S1 turbos had sodium filled valves, maybe S2s aswell?
EFi heads are all the same i believe.
Old Apr 11, 2012 | 12:44 PM
martysmartie's Avatar
martysmartie
I think what you say about the valves is correct, sodium filled exhaust valves for S1 and not for S2.
However, as for the head itself at a total guess I think they may be the same, provided it's another MFI one?
Martin
Old Apr 11, 2012 | 06:40 PM
Karlos G's Avatar
Karlos G
Balls Deep!
As Rick says any injection head will be fine, Phil is talking about heads with certain casting numbers having more meat and this is true, NMS have a nice collection of them for their serious CVH builds as they can be ported larger and fit very big valves.
S1 heads had sodium filled exhuast valves and S2's didnt.
Old Apr 11, 2012 | 06:54 PM
PhilCook's Avatar
PhilCook
Karlos, I am sure some were kind of heart shaped ones
Old Apr 11, 2012 | 06:57 PM
PhilCook's Avatar
PhilCook
NMS heart shaped heads
Open shaped
I dont know which came off what car though
Old Apr 11, 2012 | 06:59 PM
martysmartie
Ignore.
Martin
Old Apr 11, 2012 | 07:04 PM
Karlos G's Avatar
Karlos G
Balls Deep!
They are lean burn heads, they were on carb'd CVH's, flow poorly and require lots of work to make them useable.
Old Apr 11, 2012 | 07:12 PM
PhilCook's Avatar
PhilCook
Which are lean burn?
Old Apr 11, 2012 | 07:33 PM
project rs's Avatar
project rs
the heart shaped ones are leanburn
Old Apr 11, 2012 | 07:53 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah as Richie says, heart shaped ones!
Old Apr 11, 2012 | 09:15 PM
lee2cossies
Ah right shed a bit of light on this subject for me thanks! I have a brand new head and was told it's an Rs turbo one just trying to identify it! I'l get a picture see if anyone can explain too me what it's off.
Old Apr 12, 2012 | 12:35 PM
martysmartie
Lean burn engines, were designed to burn "Lean" as the name suggests, this was done for economy and emissions reasons etc.
Martin
Old Apr 12, 2012 | 04:00 PM
Rogeyboy's Avatar
Rogeyboy
If they were designed to run "lean" maybe they should've fitted them to rs turbos as some 20 odd years later most of the are running lean lol, hence the rep for smokey old cvh's burning out their rings etc...
Old May 14, 2012 | 08:01 PM
Jamie_EscortSport's Avatar
Jamie_EscortSport
I have a mfi turbo head, and Im thinking of building a head for my carbed escort.
So instead of taking my carbed one of the road whilst the head is built, just using the turbo head chaging the cam for a n/a one
Any problems with doing this???
Old May 18, 2012 | 02:19 AM
Hobomassiv's Avatar
Hobomassiv
Id quite like to know because my engine has what i think is an MFi head, it was using the dizzy, and i want to run full EFi with a coilpack. But the MFi has been ported/polished.
Old May 18, 2012 | 06:22 AM
AJC's Avatar
AJC
I have fit a Rst cam to a xr3i with no issues so think you'll be fine
Old May 18, 2012 | 06:24 AM
AJC's Avatar
AJC
You still can, what inlet manifold have you got fitted?
An adaptor plate will allow fitment or modify a mfi inlet
Old May 18, 2012 | 12:14 PM
Jamie_EscortSport
cheers mate much appreciated
Old May 18, 2012 | 12:57 PM
phil_rs's Avatar
phil_rs
yam yammer
And this is one of them that I'm selling, these are known as cross hatch heads
Old May 18, 2012 | 08:02 PM
Hobomassiv's Avatar
Hobomassiv
Its got the EFi inlet and injectors etc, it was just running Gotech management with dizzy and im going OMEX and coilpack.
I take it you can just blank off the dizzy location?
Old Sep 20, 2017 | 06:07 PM
neddy03's Avatar
neddy03
I've just built an engine from about 3 that were lying around , we've ended up with rs turbo block , head . 1.6i crank , pistons , and camshaft . all new gaskets ,bearings etc etc (as new) . we've put 200 miles on it now and it has a slight misfire under load cut a long story short the camshaft wasn't the best . I've now compared all the cams I've got and not one of them seems to be the same ?? I'm guessing rs turbo head so i need an rs turbo cam ? it also on a carb ?
Old Oct 20, 2017 | 09:30 AM
Karlos G's Avatar
Karlos G
Balls Deep!
All injection cam's are the same... But if you are using second hand ones then you need their matching lifters and for them to have been kept in the same order they came out of the head.
Old Nov 27, 2017 | 10:17 PM
Cvh_kid's Avatar
Cvh_kid
Default Rs1600i casting numbers
Hi just wondering if anyone had any information on casting numbers for rs1600i heads I've got a crosshatch cylinder head cast the 5/5/84 with a smaller number of 097832 with a 10 in a box further down to number 4 cylinder could this be an rs1600i it's also got the BRA Code any advice would be greatly appreciated
Old Nov 28, 2017 | 06:27 PM
morcheen's Avatar
morcheen
i have a similar crosshatch head ,has the BRA code and 097832 .can't see from my pics the 10 .date code is .-1-85 it was fully ported big valve head from vulcan engineering, so not sure if that was an rs1600i head originally or not.supposed to be the best heads as you can go larger on valves.not sure how true that is but from a rough measurement it looks like 43mm/38mm valves.
Old Nov 28, 2017 | 06:30 PM
Cvh_kid's Avatar
Cvh_kid
Hi thanks for replying and I think they could go 45mm valves but still unknown if it is an rs1600i head I always thought that those type of heads from 85 would be as I know that'swhen rs1600i were around at that time
Old Nov 30, 2017 | 11:03 AM
Rsmat's Avatar
Rsmat
This is a proper Mfi cross hatch Head ...this is my spare .
This is my development cross hatch Head made for flow and efficiency.
Old Jan 2, 2018 | 07:38 PM
turbo m's Avatar
turbo m
Is fitting those roller rockers a easy diy job or an expert/tuners job????
Old Jan 2, 2018 | 08:03 PM
Rsmat's Avatar
Rsmat
Yea you can fit yourself mate
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Marcus L
Aug 29, 2015 02:18 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
