engine help on the clio please
Old Apr 6, 2012 | 06:43 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default engine help on the clio please
Evening all we done a track day at croft today in the 172 and had a slight mishap lol
Sarah over took 2 cars down the back straight and suddenly the car cut out, she bumped it off in gear but it sounded horrendous (rattling noise) and had no power then proceeded to cut out again. Car won't even turn over now just clicks when you try start it, also if you put the car in gear and try move it its seems like its seized solid. I personally think its spun a shell and locked up but does anybody else have any ideas please?
Old Apr 6, 2012 | 06:46 PM
Gary F's Avatar
Gary F
It's probs just down to being French
Old Apr 6, 2012 | 06:48 PM
Dicko&Vacant
Could be a possibility Gary lol seeing as 2 out of 3 clio's there today expired.
Old Apr 6, 2012 | 06:51 PM
Gary F's Avatar
Gary F
Aye? I thought they were reliable? I never got any grief from mine.
Old Apr 6, 2012 | 06:54 PM
Dicko&Vacant
Ours had this problem and other one started over heating lol
Old Apr 6, 2012 | 07:01 PM
v man's Avatar
v man
Zee Germans are coming
snapped belt ?
broken cam shaft?
french?
Old Apr 6, 2012 | 07:05 PM
Dicko&Vacant
Belt still looks like its intact
Old Apr 6, 2012 | 07:21 PM
PhilCook's Avatar
PhilCook
The bottom pulley could have slipped. They arent keyed and resusing the stretch bolt can result in failures. The F4R rarely goes wrong, its usually human error.
I would get a scope down a plug hole, see if you can see any issues.
Old Apr 6, 2012 | 07:35 PM
Dicko&Vacant
So if that's the case i presume the rattling will of been the valves lol
Old Apr 7, 2012 | 10:11 AM
Dicko&Vacant
Had a quick look this morning and looks as if engine is seized lol can't turn engine over by hand with bottom pulley.
Old Apr 7, 2012 | 10:16 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
that bit somes up dicko nicely....
Old Apr 7, 2012 | 10:50 AM
PhilCook's Avatar
PhilCook
Time to get the head off for a look
Old Apr 7, 2012 | 11:15 AM
gup's Avatar
gup
Fanbelt hasn't jumped off and jammed in the bottom pulley
Old Apr 7, 2012 | 12:39 PM
Dicko&Vacant
Shame it wasn't me touching the belt this time Pete lol
but last week blacky fitted a new cam dephaser pulley.
Old Apr 7, 2012 | 12:58 PM
PhilCook's Avatar
PhilCook
Oooops. Sounds like the bottom pully or cambelt idler has gone
Old Apr 7, 2012 | 01:13 PM
Dicko&Vacant
I've source a 50k mile engine with fully rebuilt head new belt all pulleys etc for £350 so not even worth trying to fix this one.
Old Apr 7, 2012 | 01:25 PM
Gary F's Avatar
Gary F
You can't go wrong for £350!
Old Apr 7, 2012 | 02:10 PM
v man's Avatar
v man
takethe head off yours
port and polish
skim for more compression lol
and put it on the new engine
job done
Old Apr 7, 2012 | 05:49 PM
PhilCook's Avatar
PhilCook
When you say the new one has had belts done, I would redo it while its off to make sure its done properly. Of the timing is out it will be down to about 140bhp
Old Apr 7, 2012 | 06:44 PM
Dicko&Vacant
It's only done 5k since it was built, but looks like its been sold now anyway so back to the drawing board.
Old May 11, 2012 | 12:02 PM
PhilCook's Avatar
PhilCook
Any update on this Dicko?
Old May 11, 2012 | 12:14 PM
Dicko&Vacant
yeah seized solid mate, we bought a replacement engine for £250 and sold the fooked engine for £100 lol. lad who bought it txt me to say he's stripped it and it had span a shell which blocked oil pump
Old May 11, 2012 | 01:26 PM
Your not having much luck with cars are you dicko.
Old May 11, 2012 | 03:29 PM
PhilCook's Avatar
PhilCook
So the new lump stands you at £150. Not bad going.
Get the belts done and a good oil in there. I used Elf Evo 5w30. It was specifically designed for that engine
slammedorion
15
Nov 1, 2015 07:17 PM
hopper350
Sep 4, 2015 12:53 AM
Ben26
Aug 27, 2015 08:56 PM
