master cylinder/servo options
Old Apr 6, 2012 | 11:03 AM
griffo69's Avatar
griffo69
Default master cylinder/servo options
Hi guys, I've bought some 300mm disks with girling 4 pot calipers and braided hoses for my s2 and also will remove the abs. Would the standard servo/master cylinder be OK for these upgrades or should I change, if yes what for
Old Apr 8, 2012 | 10:14 AM
griffo69's Avatar
griffo69
Anyone
Old Apr 8, 2012 | 01:47 PM
RUBY123's Avatar
RUBY123
you can use a larger one off a mondeo they work really well but need cutting and welding to the bracket to get it to fit
Old Apr 8, 2012 | 05:36 PM
project rs's Avatar
project rs
i use a td mondeo one and makes brakes a lot sharper like the new cars
Old Apr 8, 2012 | 07:55 PM
PhilCook's Avatar
PhilCook
Is that the servo or master cylinder?
Old Apr 8, 2012 | 08:46 PM
project rs's Avatar
project rs
i use both
Old Apr 13, 2012 | 04:24 AM
B833YKJ's Avatar
B833YKJ
Use a mk5/6 escort master cylinder and servo made to fit. They came with discs all round and u don't have to cut/beat the inner wing!
Old Apr 13, 2012 | 09:12 AM
RUBY123's Avatar
RUBY123
I've got the above mondeo setup and haven't had to mesd with the inner wing it clears
Old Apr 18, 2012 | 05:27 PM
ryan_gwa's Avatar
ryan_gwa
Ive used an escort mk6 one but yet to finish the brakes off to try it. Really isnt hard to change the bracket over, ground back and painted black you wouldnt notice.
Ive also heard its hard to get the right master cylinders for rs turbo's now, but ive never searched to find out?
Old Apr 18, 2012 | 06:16 PM
PhilCook's Avatar
PhilCook
So does the escort one also need chopping about then? Are there no direct replacements?
Old Apr 18, 2012 | 06:33 PM
ryan_gwa's Avatar
ryan_gwa
Well I dont know about the mondeo one, but the Mk5/6 Escort you cant. The bolt pattern on the bulkhead and the back of Servo are different. Easiest thing to do is cut the bracket off at the bulkhead end and weld two rectangular plates on then drill the holes to suit.
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
