2wd Engine Mounts???
Old Apr 5, 2012 | 05:27 PM
RSDog's Avatar
RSDog
Default 2wd Engine Mounts???
Does anyone know which is LHS? and which is RHS? The part numbers on mine are 85HF-6038-FA and 88TF-6038-AA but have managed to mix them up
Old Apr 16, 2012 | 02:16 PM
RSDog's Avatar
RSDog
Any Ideas??
Old Apr 16, 2012 | 11:09 PM
Sonic Boom's Avatar
Sonic Boom
Not sure why they should have different part numbers when I took my old ones out to replace with Vibratech ones you couldn't tell the difference the Vibratech ones were identical too.
Rich
Old Apr 16, 2012 | 11:23 PM
BigErn's Avatar
BigErn
Do you mean the mounts or the arms that bolt to the block?
Old Apr 17, 2012 | 02:03 PM
RSDog's Avatar
RSDog
Rich
The reason they are different is that the left hand mounting was sourced from the V6 engine and the right hand mounting is unique to a cosworth according to the manual.
Not sure if that means the mounting arms or the rubber mount
Old Apr 17, 2012 | 02:04 PM
RSDog's Avatar
RSDog
I mean the rubber mounts
Old Apr 17, 2012 | 04:09 PM
Sonic Boom's Avatar
Sonic Boom
I'd have to say I don't think it'll make any differance which way round you fit them mate.
Rich
Old Apr 17, 2012 | 08:01 PM
William MK2 Cosworth's Avatar
Not 100% sure, but check the pins that the original mounts have, I believe the pin on one is closer to the bolt than the other. If you are putting uprated ones on, they shouldn't have any pin, just the bolt
Hope this helps
Old Apr 18, 2012 | 02:59 PM
RSDog's Avatar
RSDog
Hope this helps
You are right the pin offset is different.
Thanks for your reply and thanks to everone who offered advice
Old Apr 18, 2012 | 08:39 PM
cozzy jeff's Avatar
cozzy jeff
a similar question has been asked before,one of the rubber mounts is upside down to the other.
check out the drivers side mounts its spun the other way.
Old Apr 19, 2012 | 02:45 PM
RSDog's Avatar
RSDog
Thats interesting but i'd say the passenger side is fitted upside down, not sure of a reason why anyone would fit it that way?
Oct 9, 2015 07:38 PM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
