2wd Engine Mounts???
Does anyone know which is LHS? and which is RHS? The part numbers on mine are 85HF-6038-FA and 88TF-6038-AA but have managed to mix them up :oops:
Any Ideas??
Not sure why they should have different part numbers when I took my old ones out to replace with Vibratech ones you couldn't tell the difference the Vibratech ones were identical too.
Rich |
Do you mean the mounts or the arms that bolt to the block?
Originally Posted by Sonic Boom
(Post 5880981)
Rich Not sure if that means the mounting arms or the rubber mount |
Originally Posted by BigErn
(Post 5880995)
I'd have to say I don't think it'll make any differance which way round you fit them mate.
Rich |
Not 100% sure, but check the pins that the original mounts have, I believe the pin on one is closer to the bolt than the other. If you are putting uprated ones on, they shouldn't have any pin, just the bolt
Hope this helps |
Originally Posted by William MK2 Cosworth
(Post 5882015)
Hope this helps Thanks for your reply and thanks to everone who offered advice |
a similar question has been asked before,one of the rubber mounts is upside down to the other.
http://i287.photobucket.com/albums/l...f/DSCF0189.jpg check out the drivers side mounts its spun the other way. http://i287.photobucket.com/albums/l...P1010052-2.jpg |
Thats interesting but i'd say the passenger side is fitted upside down, not sure of a reason why anyone would fit it that way?
© 2024 MH Sub I, LLC dba Internet Brands
