get rid of abs
Old Apr 5, 2012 | 03:43 PM
wedge07's Avatar
wedge07
Default get rid of abs
Hi im getting an rs turbo rolling shell next month and it still has abs in the bay with gearbox.
Should i get rid or keep? When i put my efi engine in i took all abs off as had snapped belts but this is all working? Not sure wat i wanna do. Any reason to get rid?
Old Apr 5, 2012 | 04:34 PM
beaver rs 88's Avatar
beaver rs 88
in the garage
Better brake pedal feel and stronger brakes I got rid of mine and its one of the best things I've done.
Old Apr 5, 2012 | 06:23 PM
Rob_DOHC's Avatar
Rob_DOHC
Definitely get rid. Remove the rear brake compensator as well and use an adjustable brake bias valve instead
Rob,
Old Apr 5, 2012 | 06:50 PM
darrenb16two's Avatar
darrenb16two
Definatley ditch the abs mate, brakes will be a million times better
Old Apr 5, 2012 | 08:15 PM
beaver rs 88
in the garage
I've taken my compensators off the rear and am using the compensators on the innerwing like the base models used is this a good method or will my brakes be better if I got a bias valve?
tankybaby66
Feb 6, 2016 02:24 PM
Mark_
40
Oct 2, 2015 04:40 PM
