Steering rack differences
Anyone know the differences between a 2wd and 4x4 steering rack. Is it the ratio or physical dimensions?
Would fitting a 4wd (adjustable) steering column to a 2wd car work or would you need to change to a 4x4 rack and steering joint??
The reason I ask, is somewhere down the line my 2wd saff has had a 4x4 adjustable steering column fitted but its still running the 2wd rack and 2wd steering joint (rubber bush), and the steering has always been a little stiff. Wondering if this is due to the steering setup.
wowk
Mar 30, 2021 07:49 PM
SMILER258
Sep 28, 2015 09:04 AM
cosworth, difference, dimensions, focus, ford, manufacturers, power, rack, sale, saphire, sapphire, sierra, steering
