St170 Help!
Apr 4, 2012 | 11:42 AM
St170 Help!
just suddenly stopped working any ideas?
also there seems to be a little leak under the clutch pedel
Help!
Apr 4, 2012 | 12:07 PM
What suddenly stopped working. If we knew this then we may be able to help.
Apr 4, 2012 | 12:09 PM
sorry the rear window wiper..
Apr 4, 2012 | 01:05 PM
Have you checked the fuse?
Apr 4, 2012 | 01:10 PM
If the puddle under the clutch peddle is brake fluid. Clutch master clyneder is leaking and.needs replacing, check the.fuse for the.wiper motor
Apr 4, 2012 | 01:13 PM
cheers lads wheres the fuse located ? and how much am i looking at for a clutch master clyneder?
thanks again.
Apr 4, 2012 | 04:05 PM
Believe that fuse is in the glovebox compartment
Apr 4, 2012 | 04:10 PM
moved to correct section by me.
Apr 4, 2012 | 04:11 PM
The master cylinders are cheap there on ebay.It will take a good hour to fit.
Apr 4, 2012 | 04:59 PM
Apr 6, 2012 | 08:51 AM
problem solved was the relay..
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Andypandy260
Sep 23, 2015 10:28 PM
pie-face
Sep 15, 2015 10:43 AM
