Ford Range This section is for other models in the Ford range.
orion
Old Apr 4, 2012 | 08:33 AM
maido's Avatar
maido
Default orion
hi i use my orion as an everyday car and recently found out its using water i checked last week expansion tank was empty. filled kettle and put it in and it dissapeared straight away second attempt it kept the water in tank same thing happened today its got no oil in water no gunk in oil filler cap hasnt lost power dosnt overheat an fan kicks in correctly what could this be?
Old Apr 4, 2012 | 09:26 AM
pete-si's Avatar
pete-si
Have you checked for leaks when it's running. My Orion did the same. Sometimes used water and went through a period when it didn't. Was the water pump on mine. Happened the same on my diesel and petrol one
Old Apr 4, 2012 | 09:29 AM
maido's Avatar
maido
thanks for reply the only leak ive noticed is gearbox oil
Old Apr 6, 2012 | 12:39 PM
connect_4's Avatar
connect_4
You might not see the leak until the system is pressurised, ie HOT.
A friend of mine had the same issue with his Ford KA.
It turned out to be the inlet manifold gasket had gone, the water only sprayed out when driving the car and it was up to temperature.
cheers
Andy
slammedorion
15
Nov 1, 2015 07:17 PM
bassboy
Sep 10, 2015 08:54 PM
gingerturbo
Aug 11, 2015 09:44 PM
slammedorion
21
Aug 6, 2015 11:38 AM
orionguy
Aug 6, 2015 07:36 AM
