Transit connect dash fault
Old Apr 3, 2012 | 11:32 PM
langer's Avatar
langer
Default Transit connect dash fault
Hi guys my connect has today developed a fault. The fuel light is on as is the seatbelt light and a funny little fuel symbol. The temperature gauge isn't working neither is the speedo or the rev counter. Any ideas?
Old Apr 4, 2012 | 09:56 AM
DazC's Avatar
DazC
The dash clocks is an ECU. There should be some fault codes stored in it if there is a fault. It will get it's readings from the canBUS stream.
It would be worth checking all the fuses in the engine bay fuse box and the one behind the glove box too though.
Old Apr 4, 2012 | 11:49 PM
langer's Avatar
langer
All fuses are fine I'll try and plug it in tomorrow to see if it throws any faults up
Old Apr 5, 2012 | 08:39 PM
langer's Avatar
langer
Pulled the clocks out today unplugged them and plugged them back in and they've started working so god knows what was wrong with them
Old Apr 7, 2012 | 09:40 AM
DazC's Avatar
DazC
Probably just a dirty contact. Unplugging and reconnecting has probably cleaned it up a little.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Mark RS
Oct 12, 2015 06:01 AM
Neil Clark
21
Oct 1, 2015 07:02 PM
Fordmad!
Sep 29, 2015 07:03 PM
