Frs mk2 and st flo flex torque mount
Hello everyone I just had a flo flex poly bush fitted to my mount which does not even need to come off the car and took around 10 mins to fit and are being sold by Matt (guzzler) at power engineering for around £20
They can supply them in 3 different compounds
Soft / medium and hard
I've got the medium fitted and it's transformed the car for very little money
It makes the front end fell alot more tight and has helped with gear changes when launched hard
Also has reduced my axel tramp by a hell of alot, I tried quite a few surfaces wet/dry / smooth and bumpy roads and I only get alittle tramp on a bumpy road on a hard launch
If I pull away with and then floor it I used to get horrendous axel tramp but now I get none and as said I only get it when launching on a bumpy surface
So all in all I'm chuffed for such a cheap modd and thought I would share it with you guys
I've also heard that lowering springs help too so they are next on the list
Good lad it's a very good mod for very little money
I'm proper chuffed with it
The axel tramp was my only complaint when buying mine but it's gone unless you launch it stupidly hard
here you go
main body off the subframe
mount that bolts to the gearbox
and on the car
took 20 mins to fit and gives a nice feel on gear change and you dont get all the engine movement now and above all no nasty harsh vibration from the solid mount version
and on the car
I run the Vibratechics and a powerflex bush, scary difference to the standard setup!
I would advise anyone with a mk2 FRS to get this done even those who want to keep the car standard I'd say its a must. For under £100 you wont find a better mod
for a road car the Vibratechics is far to harsh !Matts kit strenghens the mount without runing the feel of the car
Each to their own though everyone has their own preference on how they want their car to run/feel etc.
Kiran1600E
11
Oct 2, 2015 11:35 AM
DavidK
Sep 27, 2015 02:55 PM
