Lowering mk6 escort van
Old Apr 3, 2012 | 08:01 AM
ssmc2010's Avatar
ssmc2010
2.0 Zetec combi
Default Lowering mk6 escort van
How do I lower a mk6 escort van with leaf springs
Old Apr 6, 2012 | 08:10 AM
ssmc2010's Avatar
ssmc2010
2.0 Zetec combi
Any ideas
Old Apr 6, 2012 | 10:52 AM
Dan j's Avatar
Dan j
Van modder
hi mate, look under you van and notice how the leaf springs are attached to the axle. what you need to do is cut the saddle bracket off the axle and weld it the under side of it then instead of the axle sitting under the springs they it sits on top of the springs.
On mine I bought some brackets off ebay for a mk2 escort and welded them on but kept the original brackets perfect to line up.
Also mine is a little different as I have added a extra leaf spring each side to stiffen the rear up and raise it 1"
The above pic is with the extra leaf springs hope this helps .
Old Apr 6, 2012 | 05:36 PM
Dan j's Avatar
Dan j
Van modder
I should add that im selling this axle as im breaking the van
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Mxkid
Aug 31, 2015 10:02 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
