Turbo elbow and pipes
Good evening
Is there anywhere that sells the turbo water pipes? Both of mine ate FOOKED so some new ones are required..
Anyone happen to have a turbo elbow with a non sticky waste gate as well?
Thanks Lewis
Thanks Lewis
Are you hell bent on keeping the turbo water cooled? My S2 and escort track car both run with no water running through the turbo. They do seem to crop up now and again on ebay but ain't cheap!
I think I have an elbow in the garage, I'll take a look tomorrow mate
Them ones at 60 on flee bay are about right for price,
Other option is to cut the pipes off and weld/braze a -6 fitting onto them and run a goodridge type hose.
You can pick the cossy ones up for much cheaper and there stainless too, doesnt make any sense what so ever
Thanks
its perfectly safe no bypass the w/cooling on the turbo. many people do it in an attempt help with heating issues, the theory been heat from the turbo is passed around the cooling system. the s1 had no water cooling anyway.
I think the water cooling it to extend the life of the turbo, imo ford wouldnt have introduced it onto the S2 if there was no advantage... The water cooling helps cool the turbo core, saves you having to run the car for 5-10mins after use to let the core cool.
Ford were probably trying to make the S2 more of an "everyday" car rather than the homologation style of the S1, as water sitting in the turbo when you turn off the ignition absorbs a lot of the leftover heat.
I think careful ownership shouldn't see any ill effects from not using the water cooling.
The series 1 ones were oil cooled and oil lubed. If u run it with no cooling what so ever it won't help its lifespan.
If you want to do it properly u would need the s1 bearing core.
NMS make there own stainless replacement pipes and Karl has just good me they are going to make a load up to sell.
Even with water cooled turbos its still advisable to leave it running to aid cooling after hard driving. I'm plumbing mine into the thermostat housing and using a -6 jic fitting to feed the turbo
I don't think it makes the car run that much hotter if im honest
So is that true about running turbo with no water. Into it would it be better to join the two waterhoses together with a joiner? What do u do with the water feeds on the turbo just leave the pipes open?
I let mine run until it cools before turning it off, luckily ive got a 3-4mile stretch of 30mph road to get to my house, gives it a nice 5-10mins to cool down! It makes little or no diff to the overall coolant temp ime and as gadget says the cores are different too so the s2 core won't be cooled by anything other than the oil thats lubing it.
If you are fussed about the hot water from the turbo heating up the engine, fit a turbo cooler rad...
andy130
Oct 2, 2015 08:48 PM
Matt Baxter
Sep 16, 2015 08:30 PM
AndrewStrang
Sep 1, 2015 11:16 AM
Escortdriver1
Aug 5, 2015 12:45 PM
Escortdriver1
Jul 31, 2015 02:36 PM
