Cosworth management Breaking GOING TO CENTRAL DAY
Hi all.
the prices do not include postage. i have priced them accordingly using janos management prices as a guid. the majority of parts where bought from jano.
all the sensors where new and have has small about of use ! everything has came of my car working perfectly and had been dry stored in separate boxes carefully
pm me for any more details
OKC stainless steel phase sensor bracket £20
phase sensore £20
phase disc £10
throttle cable bracket with cable shortened £25 AWAITING PAYMENT
crank sensore £5
crank sensor bracket £15
bottom pulley £15
alternator bracket and tensioner arm ( reburished) £15
alternator and belt £20
Throttle body modded for anti lag Slight chip on casing but docent effect it £50
iscv modded for antilag £100
ignition amps x2 £20 each
ignition amp brackets from auto specialist in black £10 each and one normal one for £5
throttle position sensore PF09 SOLD
3 bar map sensore £35
air temp sensore £5
water temp sensor £5
blue cossie injectors £35
green cossie injectors £125
OKX efi inlet manifolds ( refurbed TOP and BOTTOM) £75 AWAITING PAYMENT
efi fuel rail £5
Fuel reg £10
fuel feed "line to rail" £10
OKC T-peice vacuum pipe steup with all high pressure fittings £25 AWAITING PAYMENT
OKC efi-mfi conversion plate SOLD
FIesta rs ht leads £25
coil pack £15
coil pack bracket £5
OKC trigger ring £15
Rocker cover ( refurbed) £30
vernier cover with rubber £20
rocker cover bolts £5
exhause manifold studs £10
map sensor bracket from autospecilists £15
thermostat housing (refurbed) £15
Crossover "TURBO" bolts £5 AWAITING PAYMENT
Braided rhyan loom MINT £325 AWAITING PAYMENT
IF i have missed anything please pm me or pm me from any other pics
cheers
phase sensore £20
phase disc £10
crank sensore £5
bottom pulley £15
air temp sensore £5
efi fuel rail £5
Fuel reg £10
coil pack £15
cheers
Hi
Can you give me a drop call on 07737 513672 and i will call you back with regards to the Engine Loom, i know that you have been talking to my mate martin (Mart RS) but he has been asking me to talk to you direct so i have now registered and your my 1st pm lol.
Ady.
Ady.
Aug 14, 2015 07:29 AM
