1000cc rochdale injectors
Old Apr 2, 2012 | 05:41 PM
flannigan's Avatar
flannigan
Default 1000cc rochdale injectors
removed from my 3dr as i have had a change of plans perfect working order only covered 5000 miles max £100 delivered
Old Apr 3, 2012 | 05:34 AM
VEEDUBBED's Avatar
VEEDUBBED
Hi mate,
Can you give me more info. on your injectors? high or low ohm? can they be used with an L8 ecu? and do they need to be modded like Bosch greys to fit on the fuel rail?
Thanks.
Old Apr 3, 2012 | 08:07 AM
flannigan's Avatar
flannigan
They fit strait in the rail no mods required and I was running these on a l8 ecu with a turbo systems map / chip to suit
Old Apr 4, 2012 | 05:02 AM
VEEDUBBED's Avatar
VEEDUBBED
Great! do you still have the chip available?
Old Apr 4, 2012 | 08:47 AM
R4N SS's Avatar
R4N SS
i take it these are low impedance injectors then?
Old Apr 4, 2012 | 09:07 AM
flannigan's Avatar
flannigan
Yes they are low impedance and yes I still have the chip but you will need a pectel baby board for it to work in a l8 ecu
Old Apr 4, 2012 | 12:26 PM
VEEDUBBED's Avatar
VEEDUBBED
I've got a spare Pectel super 8 board or if not i've got the original Weber L8 board.
I'll explain a bit more, these injectors and chip aren't going on a coworth engine, there gonna be fitted onto my Weber L8 injected Vw 16v turbo engine and seeing as i already had the super 8 setup fitted i think that the board from the Pectel converted ecu should be ok.
I just need to know a few specs on the chip and what spec. your engine was, fuel pressure? turbo boost press? camshaft type? ported head?..anything you can think of really.
Let me know how much also for the chip with injectors and postage to Rome,Italy.
Cheers.
Old Apr 4, 2012 | 02:41 PM
flannigan's Avatar
flannigan
Engine spec is a t4 turbo touring car spec head 7.2 - 1 compression ratio bd14 cams 7800 rpm rev limit 2.2 bar boost 3.5 bar fuel press at atmospheric 5.7 bar on boost can't think of any more relevant info £150 +postage
Old Apr 4, 2012 | 06:35 PM
VEEDUBBED's Avatar
VEEDUBBED
Ok mate, PayPal ok?
I'll let you know my postage details through pm.
Old Apr 4, 2012 | 07:47 PM
flannigan's Avatar
flannigan
Fine with me mate
Old Apr 5, 2012 | 05:18 AM
VEEDUBBED's Avatar
VEEDUBBED
PM sent.
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
