Any auto-electricians in Manchester?
Old Apr 2, 2012 | 03:29 PM
PhilCook's Avatar
PhilCook
Default Any auto-electricians in Manchester?
Battery keeps draining on my RD Turbo and its doing my tits in now. I dont know if its a bbot light switch, dodgy central lock motor or one one the dickhead switches on the dash.
Could do with sorting ASAP so I can actually drive the thing.
If anyone local could help I would be very appreciative with a box of beers/some cash your way.
Please help
Old Apr 2, 2012 | 03:34 PM
PhilCook's Avatar
PhilCook
PS battery is fine. Is nearly new and holds its charge while off the car, but drains within 2 days when on car and car hasnt been touched
Old Apr 2, 2012 | 03:36 PM
Fordmad!'s Avatar
Fordmad!
Sure the altenator is charging it right? Should see 14v when running
Old Apr 2, 2012 | 05:54 PM
Zetecfiesta's Avatar
Zetecfiesta
Sc auto electrics in bolton, called ste give him a bell
http://www.scautoelectrics.co.uk/
Old Apr 2, 2012 | 07:31 PM
Sticky.'s Avatar
Sticky.
He's ya man Phil. He's in Geoff CSG old unit.
Old Apr 2, 2012 | 10:14 PM
PhilCook's Avatar
PhilCook
Oooh. Wonder if I get a discount for being such a gorgeous looking lad like geoff gives me?
Old Apr 3, 2012 | 12:36 PM
martysmartie's Avatar
martysmartie
The easiest thing to do is put a 'Ammeter or multi meter' in the line to measure the draw, anything other than a few milliamps is not acceptable.
The remove fuses until the figure decreases, you can then isolate the problem to that circuit.
Martin
Old Apr 3, 2012 | 04:16 PM
PhilCook's Avatar
PhilCook
Did that lastnight, traced to interior light fuse, but god knows whats chopped into that line.
Gonna take stereo out first, see if that works. Failing that I assume it will be bootlight (which I cant actually find) or cold start purge switch...... I hope
Old Apr 3, 2012 | 04:55 PM
martysmartie
The radio live feed will come off the interior light circuit, as will the boot light, but obviously you would see if this were illuminated or not?
Martin
Old Apr 3, 2012 | 05:25 PM
luke19790_3's Avatar
luke19790_3
does the car have a alarm?
Old Apr 3, 2012 | 06:50 PM
PhilCook's Avatar
PhilCook
Sorted. The state of the wiring behind the radio was laughable. Like spaghetti.
So, as soon as I pulled that out, the drain dropped off. Winner.
Old Apr 4, 2012 | 01:10 PM
martysmartie
It could even be the head unit itself.
Martin
Old Apr 4, 2012 | 04:03 PM
PhilCook's Avatar
PhilCook
Aye. Thats on the floor in the shed and is staying there.
Having boost, oil pressure and temp gauges there instead
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Zetec Andy
21
Aug 2, 2004 09:37 PM
Zetec Andy
17
May 16, 2004 01:04 PM
Zetec Andy
27
Apr 15, 2004 04:12 PM
