Mondeo 300mm brakes
Old Apr 1, 2012 | 10:34 PM
escort_rst's Avatar
escort_rst
Default Mondeo 300mm brakes
Hi all. Searched the forum but can't seem to find a solid answer to my question. Does the mondeo 300mm brake conversion fit under standard s2 wheels with some grinding? Has anyone tried? Some people say yes and some no but want a clear answer for defo. If not i'll have to settle for cossie brakes.
Cheers. Alex
Old Apr 2, 2012 | 07:02 AM
Rogeyboy's Avatar
Rogeyboy
They fit under some 15s with some grinding... Maybe under turbo wheels with "alot" of grinding.
Not very helpful i know - but as you say cossie brakes do and would be an ideal upgrade!
Old Apr 2, 2012 | 10:11 AM
escort_rst's Avatar
escort_rst
cheers mate. yeah cossie would be the easiest but was just wondering with a bit of effort if the mondy ones would fit. i'll wait and see if anyone has tried it if not i'll decide wheather to chance it and try mondy ones or just go for cossie.
cheers. Alex.
Old Apr 2, 2012 | 05:10 PM
16vzetec's Avatar
16vzetec
No straight answer then lol. I'm wanting to know if they fit under sharktooths. Think the only way is to try it. Not simple to do. If someone has a mk4 hub I have mk3 mondeo calipers here to try
Old Apr 2, 2012 | 08:46 PM
Joe91's Avatar
Joe91
Yes they do fit mate, I have them on mine
Thanks, Joe
Old Apr 2, 2012 | 09:29 PM
makaveli96's Avatar
makaveli96
Joe you have the discs fitted the other way round mate.
Old Apr 2, 2012 | 09:37 PM
16vzetec's Avatar
16vzetec
how much grinding?
Old Apr 3, 2012 | 06:21 AM
paul-h's Avatar
paul-h
As above, how much grinding!! Ha!
Old Apr 3, 2012 | 07:08 AM
Joe91's Avatar
Joe91
that was a test fit for a picture they are the proper way don't worry!
Alot of grinding, took maybe 4-5hrs of grinding then fitting then grinding more etc etc, pain in the arse but looks good!
Thanks, Joe
Old Apr 3, 2012 | 03:29 PM
paul-h's Avatar
paul-h
How much of caliper is left? Haha!
Old Apr 3, 2012 | 06:20 PM
16vzetec's Avatar
16vzetec
I'm an engineer so can machine off metal to suit but if it's going to be too weak I won't do it
Old Apr 4, 2012 | 07:02 AM
Rogeyboy's Avatar
Rogeyboy
Also the escort turbo in that pic is running st170 calipers, i run mondeo calipers (mk3 st220, but all mk3s are the same)
They fit under sharktooths with minimal grinding... Seen this done!
Old Apr 4, 2012 | 12:25 PM
escort_rst's Avatar
escort_rst
Ah that's good I've seen it done now lol I think I'm going to go and buy the mk3 callipers and get grinding lol. There's no difference between the st170 and mk3 callipers is there? Except mk3 ones have slightly bigger pistons?
Thanks. Alex
Old Apr 7, 2012 | 06:12 PM
16vzetec's Avatar
16vzetec
There are two different calipers for the 300 mm disc's one was on the early st220 petrol models and st170 and then the STD mk3 type which I found worked better at speed! I used mk3 disc's before as offset is better suited to escorts but this requires drilling 3 holes in the disc to match the escort stud pattern
Old Apr 8, 2012 | 12:19 PM
paul-h's Avatar
paul-h
Not into drilling extra holes, I just used the st170 discs, job done!
Old Feb 21, 2016 | 08:26 PM
Anj's Avatar
Anj
Hi Will the rst s1 15" rims clear the calibers with grinding
AS i just bought This set the other day.
Old Feb 25, 2016 | 06:35 PM
Chas's Avatar
Chas
I think they may but they will require more grinding than the S2 wheels would. My Cosworth brakes fit under S1 wheels and they are a tight fit:
Brickhouse
14
Oct 3, 2015 07:28 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
