Headlining material?
Old Mar 31, 2012 | 05:36 PM
Karl 3dr's Avatar
Karl 3dr
Default Headlining material?
Looking at retrimming the headlining on my car, has anyone else done this and what did you use/where did you get it from/prices etc?
I want it to look as close to original as possible
Thanks, Karl
Old Mar 31, 2012 | 05:52 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
I have been able to get hold of the correct stuff before for a load of people on here m8, can ask if the trimmers have any in stock for you if ok.
Steve
Old Mar 31, 2012 | 05:55 PM
Karl 3dr's Avatar
Karl 3dr
Thanks Steve, be much appreciated if you could mate!
Karl
Old Mar 31, 2012 | 06:15 PM
charlie luciano's Avatar
charlie luciano
My recent headling jobbie
https://passionford.com/forum/restor...-page-2-a.html
Luciano
Old Mar 31, 2012 | 06:22 PM
Karl 3dr's Avatar
Karl 3dr
Cool , looks like they did a top job of it mate!
I've got the numbers of a couple of trimmers around here but i was hoping to have a go myself tbh, i'll probably fuck it up never mind lol
Karl
Old Mar 31, 2012 | 06:40 PM
Rsmat's Avatar
Rsmat
I helped do one the other week... Was a pig to do getting all the glue and old sponge off its like pollen....ended up going to trimmers who charged Ł100 looks brand new and factory..!
Old Mar 31, 2012 | 06:47 PM
Karl 3dr's Avatar
Karl 3dr
Yeah, i sripped all the old glue off mine today, horrible, sticky shit lol
That's a good price too Matt!
iansoutham's Avatar
iansoutham
OCD Victim
Use a DA and some 800 grit pads. Comes off nice and easy without wrecking the cardboard.
Old Mar 31, 2012 | 08:06 PM
Ive tried to do 2 head linings and a few months later they have just sagged again.
Old Mar 31, 2012 | 08:58 PM
iansoutham's Avatar
iansoutham
OCD Victim
What glue are you using? You need hi-temp glue that goes to @ least 120 degrees or the heat in the sun will cause it to sag again.
Also, are you removing all the original material and backing before applying glue, applying a base coat of spray glue to provide the adhesive something to grip against and are you leaving the adhesive the recommended time before putting the material onto the board?
Here is some of how I did mine...
I also did my A, B and C-pillar trims as well so that everything above the doorcards matched, similar to newer Fords.
Old Mar 31, 2012 | 09:03 PM
Rsmat's Avatar
Rsmat
That's a great job mate...^^
Old Mar 31, 2012 | 09:08 PM
Karl 3dr's Avatar
Karl 3dr
That looks great! What material did you use btw?
Karl
Old Mar 31, 2012 | 09:12 PM
iansoutham's Avatar
iansoutham
OCD Victim
I got the material from East Kent Trim Supplies. Is as close as I can find to the original and comes with the foam on the back already. The only difference between that and the original stuff is the fact that the original is 20 years old and has dirt ingrained into it which will never come out. Hence, you have to do the C-pillar trims at the same time. Once you take the material off the pillar trims though, they are the same as non-Ghia/RS models so easily available if you wanted to pre-trim some.
Old Mar 31, 2012 | 09:14 PM
iansoutham's Avatar
iansoutham
OCD Victim
My best recommendation is to take your time on the prep stage. Get this wrong and it will all be for nothing. Also, when applying the adhesive, there is no such thing really as too much time taken. Rush it and it will be rubbish within a month.
If you can get hold of a smallpaint roller-type thing, even better. If you use your hands to push the material out, it will show the imprints from your finger. I normally use an old bank card and spread the material on using light pressure.
Old Mar 31, 2012 | 09:23 PM
Karl 3dr's Avatar
Karl 3dr
Ok, thanks a lot for the advice mate
Now to find some material lol
Old Mar 31, 2012 | 09:33 PM
neil andeRSon's Avatar
neil andeRSon
I got a headliner out of a glx that i'm gonna do black. Was thinking to put some thin foam on first then some black alacantra type stuff on..
andyrs1600i
Apr 29, 2026 03:21 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
Vincereese
Sep 18, 2015 12:48 PM
Vincereese
Sep 18, 2015 12:47 PM
