PISTON 2 DEAD!!! UPDATE HEAD OFF - PICTURES NOW INCLUDED!!!
Old Feb 26, 2005 | 04:50 PM
DaveEscos's Avatar
DaveEscos
Default PISTON 2 DEAD!!! UPDATE HEAD OFF - PICTURES NOW INCLUDED!!!
misfire at top end in 5th, pull in to the middle lane and smoke coming from the back
great!!
cant be turbo as its brand new (50 miles! )
if i had melted something, surley it wouldnt drive as i managed to drive it home (20 miles)
1) smoke (whitey blue) pissing from the exhaust on overrun and taking off
2) big oily haze on tarmac under the car
3) sounds like a tractor, misfiring everywhere
what are the odds its the headgasket (grp a shitter)?
or is it a blown engine?
thanks guys fecking car!
TIFF's Avatar
TIFF
Chasing Radders
Did you run the turbo in properly??????????????????????????????????????????
Old Feb 26, 2005 | 04:51 PM
DaveEscos's Avatar
DaveEscos
its not turbo tiff.. misfires off boost
and yes i did....
Old Feb 26, 2005 | 04:53 PM
Ryan's Avatar
Ryan
that would make me think turbo
Disabled Account's Avatar
Disabled Account
Do a compression test AND a leak down test Dave...........also check for a melted spark plug tip.
Old Feb 26, 2005 | 04:54 PM
Kev.H's Avatar
Kev.H
scrap it
Old Feb 26, 2005 | 04:56 PM
ECU Monitor Enthusiast
Sounds like a broken piston to me
Time for a bank loan .....
Old Feb 26, 2005 | 04:57 PM
DaveEscos's Avatar
DaveEscos
will do doug
the funniest thing was.. at the dartford tolls.. behind a car.. smoke pissing and i mean PISSING everywhere... woman at the side says to the bloke .. dont let him leave... up the gate goes.. they tell me to pull over... up goes the finger and ta ta! of I burn at 5 miles an hour chugging like a tractor
cnt catch me!!
im not pissing around on the dartford crossing with jobsworths !
Old Feb 26, 2005 | 04:59 PM
DaveEscos's Avatar
DaveEscos
really? bollocks, i really cant be arsed to sort a new bloody bottom end out!
compression test will tell me yes?
Disabled Account
Dave, cars have feelings too..........it prob heard about all that cosmetic surgery (WRC) that you planned for it..........
Engine thought to itself "it's hardly worth living anymore"
Old Feb 26, 2005 | 05:01 PM
DaveEscos's Avatar
DaveEscos
Ryan's Avatar
Ryan
yeah comp test would tell you if you had a hole probably wont get fook all compression showing, or if you had done a gasket would be low on 1 cylinder or 2 if its between bores
Old Feb 26, 2005 | 05:02 PM
Kev.H's Avatar
Kev.H
Imagine what the car thinks when the owner gets in clad in bureberry no wonder its red its fecking blushing
Old Feb 26, 2005 | 05:04 PM
DaveEscos's Avatar
DaveEscos
doug, do you still have that complete engine
Old Feb 26, 2005 | 05:06 PM
Kev.H's Avatar
Kev.H
fine ignore me u spunk nut did u get ur frigin club >??? last time i help you i tell ya well till next time
Disabled Account
dave is the oil level low......or colse to what it was when you last chevked it???
a hole'd piston of cracked ring throws out lots of oil is a very short time.....
Old Feb 26, 2005 | 05:07 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
that sounds remarkable like when i did a piston on my 3dr back when it was on greens...
I hope its not pistons for your engine
but here are of my previous "random aluminium sculptures"
Old Feb 26, 2005 | 05:08 PM
Mark Shead's Avatar
Mark Shead
Dave pull plugs out and check, Most likely you have dropped enging, did you check the fuel pump volts with the electric problem you have.
Mark
DaveEscos's Avatar
DaveEscos
kev fook off kitty! yes i got the club, cheers pal
ill check tomorrow Doug, im hoping its just the gasket to be honest ..... what a pisser
saying that! the water temps were extremely low on the secs monitor and the gauge.. about 60 deg!!! once warmed right up!
could this point towards head gasket! ??
Disabled Account
Yes Dave, I've still got a complete engine...........but it is "sort of" not for sale at the moment..........Would be A LOT CHEAPER to get yours rebuilt by Brom than buy my one.....
Old Feb 26, 2005 | 05:11 PM
Kev.H's Avatar
Kev.H
buy this engine
https://passionford.com/forum/viewtopic.php?t=104437
hope its not 2 major
Old Feb 26, 2005 | 05:14 PM
DaveEscos's Avatar
DaveEscos
hi mark, i sorted the volt problem, ecu was getting 13.9 v and fuel pump was fine
its going to be a new bloody engine isnt it
Old Feb 26, 2005 | 05:15 PM
Ryan's Avatar
Ryan
dave what did you do in the end regards wiring?
Old Feb 26, 2005 | 05:16 PM
Mark Shead's Avatar
Mark Shead
Pull the plugs out this will give you the best Idea
Mark
Old Feb 26, 2005 | 05:18 PM
Disabled Account
Check plugs!!!! Look for a melted tip......or very light colour on one or more of the tips..suggesting that you mat have had lean mixture/failed/blocked injector
DaveEscos's Avatar
DaveEscos
Ryan, i fed a 12v fused ign supply to the ECU pin 20. sorted
Mark, Doug will do
i hope they are intact... bloody things cost Ł60!!
Old Feb 26, 2005 | 05:27 PM
DaveEscos's Avatar
DaveEscos
right.. im off to drown my sorrosw in a nice young blonde girl! and a few drinks!
please leave many ideas as poss so i can read them when I ...
a) get in pissed tonight with a slap mark on my cheek
b) when i get in in the morning with slap marks on my bum cheeks!
night all!
Old Feb 26, 2005 | 05:30 PM
adamS2RST's Avatar
adamS2RST
Old Feb 26, 2005 | 05:33 PM
Disabled Account
Old Feb 26, 2005 | 05:34 PM
DaveEscos's Avatar
DaveEscos
doug, pm me if you have that engine still
byyeeee
Ryan's Avatar
Ryan
Old Feb 26, 2005 | 05:36 PM
Dave, he is saving that engine for a transplant into the MR2 ....
Old Feb 26, 2005 | 05:37 PM
Lee Reynolds's Avatar
Lee Reynolds
Hope its not a meltdown dave....even tho its u
What colours the water and have ya lost any?>
Old Feb 26, 2005 | 05:38 PM
steviep's Avatar
steviep
Expect him to reply tonight then
Old Feb 26, 2005 | 06:24 PM
Alvyn's Avatar
Alvyn
that DONT sound like head gasket to me more like it's run lean for what ever reason and put a hole in one or more of the pistons what new plugs did you use and what was your engine spec etc?
ps drove mine home 20 miles smoke out the back drank loads of oil no water loss and 1 piston was holed when 1st engine let go with Ł100 worth of so called NGK racing spark plugs
Old Feb 26, 2005 | 06:34 PM
Disabled Account
Alvyn, thats what I was thinking too......more like it has run lean.
He said that his plugs cost Ł 60.00....So I guess they must be NGK 9's
Dave's engine spec???? Oh yes: "Heavy on the Aeroquip"
Old Feb 26, 2005 | 06:45 PM
Ryan's Avatar
Ryan
Old Feb 26, 2005 | 07:03 PM
ImaRacing 700's Avatar
ImaRacing 700
Who mapped it?
Old Feb 26, 2005 | 07:13 PM
Chris Honeywell's Avatar
Chris Honeywell
Shes melted m8
Dont worry we have all been there
