Cossie bottom end parts inc 2 x 200 blocks.
Righto the cossie clear out is long over due so here goes.
200 block, .5 bore, small crack across a head bolt.
I believe this can be fixed by long studding the block.
£200
Next is a complete bottom 200 bottom end bar the sump. It was a new block when built but I melted it.
I believe this is an original crank but cannot confirm. as it's still in the block.
I'm not sure how to price it but
crank £180
rods £120
block £500
Other gubbins = fuck knows. £50?!
£700 for the bottom end as it stands?!
I have another crank from my other engine that was ground and polished through Mike Rainbird. It is 0.25 grind
It has done FA since it was reground. £300
If anyone wants the lot then £1000.
I will be taking my cossie to England for mapping around 18th April and returning for it 4 days later ish. I could meet anyone on route if need be.
Chop
£200
crank £180
rods £120
block £500
Chop
Oct 9, 2015 07:38 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
