bespoke steering column kit/bearings
Old Mar 26, 2012 | 07:11 PM
Luca's Avatar
Luca
Lukesville
Default bespoke steering column kit/bearings
Anyone know of a company that supply these parts please?
Old Mar 26, 2012 | 07:15 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Give Ian a ring at Webster Race Engineering on 01933 315236
Old Mar 26, 2012 | 07:44 PM
Luca's Avatar
Luca
Lukesville
Shall call in morning, thanks Will.
Offered the pedal box up and the standard column structure is ever so slightly in the way.
May swell get the right wheel position while everything is out and remove the flex steel Ford supplied.
Old Mar 26, 2012 | 07:50 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
If this is what you're looking for then any bearing supplier or RS Components will have them...
Old Mar 26, 2012 | 08:11 PM
Luca's Avatar
Luca
Lukesville
[QUOTE=Martin-Hadland;5854331]If this is what you're looking for then any bearing supplier or RS Components will have them...
cheers martin, any idea where the bracket is sourced.
Seen ones which bolt to the roll cage but id rather it welded i think... like below
http://www.ludlowmotorsport.com/prod...roducts_id=165
Old Mar 26, 2012 | 08:12 PM
Luca's Avatar
Luca
Lukesville
tankybaby66
Feb 6, 2016 02:24 PM
IainRS1700T
Sep 25, 2015 06:44 AM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
