3dr Shell Strengthening?
Hi
I'm going to dismount all my 3dr sierra to change colour, So I want to ask you if there is any manual where I can check how can I improve rigidity with welding tweaks.
I can't fit a rollcage because is a car for road use (and a few trackdays)
For now I 've front and rear strut braces (I will probably modify rear strut brace to be 3 point instead 2)
I've a manual called "Competition preparation for Ford Sierra models", it says to reweld every spot-welded body pieces you can. But is more focused to use a rollcage
The spot welding is a good start and can stiffen the shell alot. I think in the book are also mentioned rails that are added under the floor these do quite alot of magic!
Next thing i would consider is strenghtening the front between the a pillars and stut tops, that is a wery weak spot on the sierra i think, escort cosworths had this allready sorted out:
I only want to improve the stiffness of the shell for trackdays, as is in the circuit when I miss to have more stiffnes.
Starded today to spot welding the front struts area (As I said, my welding skills are bad, so my weldings are not very good looking
Have a look at an XR4Ti..... they have very stiff chassis from the factory.... the 909 motorsports stiffeners for the 3dr Sierra's are a direct copy. With a set of strut bars an XR4Ti is a pretty stiff car
SMILER258
Sep 28, 2015 09:04 AM
