4WD Thermostat leak ?
I've a brand new 4WD Thermostat Housing & Elbow.
I've fitted a brand new Ford Thermostat as well.............now its leaking from the joint between the two.
Both faces are flat and clean !?!
I've a new rubber seal (O-Ring) between the two (bought from Burton Power) - is it worth making a thin gasket or using a sealant ?
Can't really understand why it's strung a leak ?
Anybody had the same issues
When i changed mine ages ago i used the paper gasket and a thin layer of silicone to seal mine.This was like this for a good 2/3 years.Ive put an updated thermosat in my car now and this time i used the rubber gasket supplied.
The gasket goes round the edge of the thermostat.When i was putting mine in there was a gap between the thermo housings and i thought it wasnt right.I just kept tightening the bolts up till the housing nipped up flush.
The Enigma
Sep 29, 2015 10:31 AM
