ST170 Turbo?
Old Mar 24, 2012 | 11:31 PM
coozer's Avatar
coozer
Default ST170 Turbo?
I have a St170 engine I want to turbo.
I wanted a blacktop to start but the ST came along cheap so why not, its much newer than an old blacktop and has a better head...
Anyway, this has thrown up some questions??
The pistons and rods are different to standard fair but I'm wondering if its just a simple matter of throwing in a set of low comp cosworth or wossner forged jobs on the standard rods.
Are the rods in the ST170 the same dimensions as a blacktop? length, pin size.. Or, do I need special pistons?
Then there's the cams. ST ones are very lumpy and there's the VVT. Does this work in a turbo setup or is it best to fix the inlet to limit the overlap??
Any help would be much appreciated
Steve
Old Mar 25, 2012 | 06:14 AM
.Ross.'s Avatar
.Ross.
Have you looked into Supercharge's mate?
Old Mar 25, 2012 | 02:48 PM
coozer's Avatar
coozer
Yep, looked at supercharging and NOS.. diy turbo is the cheapest and biggest bhp!
First thing I need to know if the ST rods are the same or different to a normal blacktop.
Steve
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
Jerry Ryan
Sep 2, 2015 08:02 PM
kevin36
Sep 2, 2015 06:24 PM
