how to fit a turbo timer
i have had for a while now an apexi turbo timer not the most hitech of them all but everything i need!
im going to set the time manually so i dont need to connect it to a/f sensors etc.
i just want to take the key out the ignition lock the doors walk away and let the car shut its self down in the time i have set.
where do i have to wire it too? is it all at the ignition barrel or is it a little more complicated than that!
marky_g
Aug 15, 2015 10:43 AM
