What brake kit for 16 inch wheels?
Old Mar 21, 2012 | 12:07 PM
Weeksy's Avatar
Weeksy
Default What brake kit for 16 inch wheels?
Hi All,
I see most companies do 325mm and 330mm brakes kits to fit behind 17's, but nothing smaller (that I have seen) for my 2wd Sapphire.
Does anybody know of any brake kits using 305 or 310mm discs?
Your thoughts would be much appreciated
Thanks
Weeksy
Old Mar 21, 2012 | 12:43 PM
Fast_Wyvern's Avatar
Fast_Wyvern
Compbrake do 300mm, but not sure how good they are, I'm looking at the 330mm
Sorry the 300mm I saw were for Rear kits
http://www.compbrake.com/cars/ford/e...brake-kit.html
315mm for 16" Wheels
Old Mar 21, 2012 | 01:27 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
well how are you at making a simple bracket?
with a bit of time you can fit focus rs mk1 discs (324mm) and callipers under 16's but are tight.
i did just that on my xr2, surely it can be done with others, but does depend on the wheels of choice.
off the shelf will be smaller as listed above.
Old Mar 21, 2012 | 05:09 PM
Weeksy's Avatar
Weeksy
I wouldnt trust myself to make a bracket for brakes!
Will 324mm and the RS brembos really fit?
I am not sure how meaty the Revos are to give clearance on these...
A have a spare wheel, so may be worth getting a spare hub and having an engineering firm knock some up?
Old Mar 21, 2012 | 08:59 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
you can get brackets off ebay IIRC, yes they will fit, mine are close to the wheels though, the weights were the biggest issue, had to grind the callipers down a little.
but how else could you get brembos and 324mm discs with pads for less than Ł250
Old Mar 21, 2012 | 10:24 PM
stevieturbo's Avatar
stevieturbo
C**t
Originally Posted by Weeksy
Hi All,
Thanks
Weeksy
More importantly....what wheels ?
Ive 330mm's behind 16" Comp MO's
Old Mar 22, 2012 | 12:18 PM
Ridgey's Avatar
Ridgey
I'm running 32x320mm kit behind my track wheels (8x16), compbrake kit with large 4 pot Brembo caliper.
Email Tony at 909sport details in my Sig.
Old Mar 22, 2012 | 12:20 PM
Weeksy's Avatar
Weeksy
I run revo RFX's
Dont know if they are hefty or slender compared to others in the critical areas!
Old Mar 22, 2012 | 12:39 PM
JonnyBravo's Avatar
JonnyBravo
Me too
Old Mar 22, 2012 | 12:53 PM
Rogeyboy's Avatar
Rogeyboy
XR2wishy - im loving the brembos under the 16s... My 300mm mondeo/st170 combo fills mine pretty well or so i thought, gonna look for brembos and 324mm discs next!
Where did you get the brackets? Or can you remember sizes etc?
Old Mar 22, 2012 | 01:37 PM
Weeksy's Avatar
Weeksy
Loving the XR2 on RS brakes.
I have to try that conversion I think
Hope the old revolutions arent too small / chunky!!
Anyone know of a pair of calipers going spare? Will buy new discs pads etc
THanks
Weeksy
Old Mar 22, 2012 | 06:27 PM
cos 4x4's Avatar
cos 4x4
You can fit the st170 mk3 mondeo conversion which are 300mm . I have then under escort caosworth rims on my xr4i have a look in the cossie section on here there's a pic of mine on there
Old Mar 22, 2012 | 08:58 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i made the brackets from 10mm steel, fitted with M12 high tensile bolts. not that difficult as i made the first template from 3mm steel as it's easier to shape over the 10mm.
only needed minor adjustment on the car, work very well indeed, especially at high speed, car just seems to halt rather than pitch.
Old Mar 22, 2012 | 09:11 PM
stevieturbo
C**t
Just use some 10mm MDF as a template. Easy cut and shaped
Old Mar 22, 2012 | 10:48 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
/\ just happen to have steel to hand, no wood, good tip for next time though
Old Mar 26, 2012 | 10:38 AM
Weeksy's Avatar
Weeksy
Right, I have the calipers now, but will the bloody things firt inside my Revos...
Time will tell!
If you boys are running 330mm AP kits behind your 16 inch comps, surely I have half a chance?!
Or are the APs quite slim compared to these chunky looking brembo badboys?! On that note, anybody got a pic of them together!?
Thanks for the info XR2Wishy.
Old Mar 26, 2012 | 11:41 AM
Rogeyboy's Avatar
Rogeyboy
So they have a 10mm offset difference?
Good tip using some mdf etc... Ive got a spare hub lying around, just need some brembos now!
Old Mar 26, 2012 | 01:18 PM
Weeksy's Avatar
Weeksy
I dont think its the offset , just the thickness of the steel he used to space the calipers out from the original caliper hub mounts..
Old Mar 26, 2012 | 05:35 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
on my xr2 the offset difference was only 2mm if i remember correctly.
the 10mm steel was to make sure they didn't bend at all.
best thing to do is get a disk and calliper and see if the discs centres on the wheel and calliper fits round the edge, i did have to grind a little material off the calliper though and i was already using 5mm spacers too.
Old Mar 27, 2012 | 08:00 AM
Weeksy's Avatar
Weeksy
I wish I had a crappy old pair to hand to model them up!
I really dont want to use spacers! Asking too much here arent I?!
Old Jun 14, 2015 | 05:46 PM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
Is there any way that 330 mm discs and for example AP 4-piston brake kits would fit inside any 16'' wheel on 4wd Sierra Cosworth? I have 3-piece split rims (Compomotive CXN) 16x9 with low ET, 17 if I remember correctly. Inner diameter of rims is around 398 mm so are there any 16'' wheels out there that could house big brake kit or is 17'' wheel the only choice?
steerfromdarear
28
Jan 29, 2016 06:14 PM
YODI
Aug 30, 2015 01:12 PM
borboyous
Aug 22, 2015 11:17 AM
cossynut2
Aug 19, 2015 11:29 AM
RsS2daz
Aug 14, 2015 05:26 AM
