Rover split clutch pipe???
Old Mar 20, 2012 | 08:36 PM
turboRS's Avatar
turboRS
C16OSY
Default Rover split clutch pipe???
Rover 75 with the split connector on the clutch hydraulic pipe.....
Anyone ever struggled to push it back together???
I used the tool remove it ok enough, but by fuck it does not want to go on to the new slave cylinder ( correct part )
Old Mar 21, 2012 | 07:48 AM
shalon's Avatar
shalon
Usually they snap together quite easily bit more difficult to get them to separate are you replacing a bit sometimes a Pattern part needs to mate up to the same make if you know what I mean euro car parts are quite reasonable for them
Old Mar 21, 2012 | 09:25 AM
turboRS's Avatar
turboRS
C16OSY
In the past they have just snapped together as u say, but this one just does not want to know! it is a Sachs unit aswell!!
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
AJC
Oct 1, 2015 06:47 PM
mpilk
Sep 27, 2015 09:21 AM
