Collecting full efi kit tomo, please check i aint forgot anything
Old Mar 20, 2012 | 08:11 PM
seans saff's Avatar
seans saff
Wink Collecting full efi kit tomo, please check i aint forgot anything
Ok here is a list of what im collecting please let me know if iv missed anything
Inlet with throttle body, injectors, fuel rail, pressure reg, throttle sensor, iscv
Ecu plus engine and injector loom
Coil pack
Plug leads
Sensors for engine including cps
Flywheel
3bar map sensor
Co2 potentiometer
Fuel pipe from filter to rail
Throttle cable
Hose from turbo to filter
Need find a charge carrier,
Finally what is a map sensor surpressor???
Cheers people
Old Mar 20, 2012 | 08:19 PM
studabear's Avatar
studabear
is this going on a cvh, has the block got the hole for the cps?
Old Mar 20, 2012 | 08:23 PM
seans saff's Avatar
seans saff
Its a 2.0 zetec block (2.1 zvh), was told it will have one allready is that right?
Old Mar 20, 2012 | 08:32 PM
seans saff's Avatar
seans saff
Can anybody tell me what a map sensor surpressor is?? As i think i need it but not sure what it is or looks like
Thanks
Old Mar 20, 2012 | 09:02 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
Ths map sensor supresser is a little black box that plugs in to the loom,it has 3wires going in to it and is about 1inch square big, should be already on the loom but they get chopped out when up grading to a 3bar map sensor,
Old Mar 20, 2012 | 09:04 PM
seans saff's Avatar
seans saff
cheers for that
Old Mar 21, 2012 | 06:04 PM
rs-tuner's Avatar
rs-tuner
Aren't the cvh heads different if going from mfi to efi?
Old Mar 21, 2012 | 06:13 PM
seans saff's Avatar
seans saff
Yes but can fit an adaptor plate to sort this
Oct 9, 2015 07:38 PM
matman
Sep 9, 2015 05:45 PM
EoinXR3
Sep 7, 2015 05:44 AM
borboyous
Aug 22, 2015 11:17 AM
RsS2daz
Aug 14, 2015 05:26 AM
