Help With Spraying My Plastic Bumpers
Old Mar 20, 2012 | 04:07 PM
Gaia's Avatar
Gaia
Default Help With Spraying My Plastic Bumpers
Hi,
I have a white Ford Fiesta Encore 1.3 1998. Some of the paint has come off both bumpers. I'm intending to get a can or two of Ford matching paint and primer from Halfords.
Can someone explain the steps I need to take to spray up the areas where the paint has come off? Spraying the primer on the area concerned, then the white top coat on that seems straightforward enough. I think.
I'm wondering though, about flatting down to provide a key? What grit, wet or dry? Don't the flatted sanded area and the sprayed primed area need to be exactly the same size and how do I do that? If I sand an area and then prime it, but say if there is a 1 inch over spray boarder around the flatted area, will the primer not adhere there, and the scratch marks will be visable?
I know what I mean but is a bit hard to explain.
Also same as painting a door where paint has flaked of, will be an uneven surface and the flaked areas will be clear even though has been painted.
Will I have same sort of problems with bumpers if so, how do I avoid.
Cheers.
Old Mar 20, 2012 | 04:37 PM
dingla rs's Avatar
dingla rs
first off you need to sand the area back were the paint has come off till there is no edge ,1200wet an dry will be fine or 800 ,you need to flat past the arear you intend to primer and dont prime rite up to ur taped edge so when you flat the primer down you wount be left with a edge ,also you will need a plastic primer
Old Mar 20, 2012 | 04:39 PM
jammerrs's Avatar
jammerrs
Firstly you will need plastic primer, colour paint, then laquar.
I'd recommend 800+ wet and dry, used wet.
Flat down the area quiet a good way around the area, dry, spray primer, wet flat, dry, colour, laquar, wet flat and polish
Use finer grades the further along the spraying process you are, you may need filler primer depending on how deep the scratch is, in witch case, use after you've flatter the plastic primer down, then flat that down before colour.
One more thing, mask off the area not to be sprayed, try and tie this into lines of the car if possible, note the colour will be more vivid as it's not exactly matched to your car, the whole bumper will need flagging and polishing to help it blend in
This is based on my limited knowledge of spraying so don't take it as gospil
Old Mar 20, 2012 | 06:08 PM
Gaia's Avatar
Gaia
OK ta very much.
I follow what you say up to here. " you need to flat past the arear you intend to primer and dont prime rite up to ur taped edge" I don't quite follow you here, could you explain more clearly to me please?
Cheers,
Peter.
Old Mar 20, 2012 | 06:15 PM
Gaia's Avatar
Gaia
OK thanks for that. What other grits of paper should I use?
" laquar " I thought the Halford paint would be a gloss do I need the laquere? Again polish, do I need it? I just want to tidy the car up, not put it in a show sort of thing.
Thanks mate,
Peter.
Old Mar 20, 2012 | 06:26 PM
dingla rs's Avatar
dingla rs
Originally Posted by Gaia
OK ta very much.
Cheers,
Peter.
if your just priming the bumper you normly mask off the arear that you dont want paint on or primer like this altho its just a guid to show you what i mean
so thats first set flat arear down thats flaking with 800 till there is no edge ,mask the arear off so no primer gets on wing ect ,plastic prime ,dosnt need sanding at all then primer witch will need flatting ,flat the old paint to the nearest edge or line remask and put the topcoat on
Old Mar 20, 2012 | 07:10 PM
Gaia's Avatar
Gaia
I'm with you. Will post pictures of bumpers Wednesday, so you can see more clearly areas I need to tidy up. I got new numbers plates and wheel trims the other day from Ebay, really good price. Also a replacement wing mirror unit that I need to spray. I know very little about cars, but you guys really do, awesome
Cheers.
Old Mar 20, 2012 | 11:48 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Dont apply too much pressure to your sand paper! You only want to key the surface if you apply too much pressure you will see the scratches.
Old Mar 21, 2012 | 06:39 AM
whizzisat114's Avatar
whizzisat114
Try and use a sanding block where ever you can to reduce any uneven flatting
let the paper do the work. Dont press too hard
and use washing up liquid in your water to help lubricate the paper.
Old Mar 21, 2012 | 12:24 PM
Gaia's Avatar
Gaia
OK thanks, uploading bumper photos now.
Old Mar 21, 2012 | 12:29 PM
Gaia's Avatar
Gaia
Cheers, uploading photos of bumpers.
Old Mar 21, 2012 | 02:12 PM
Gaia's Avatar
Gaia
Default Fiesta Encore Bumper Photos Link
Hi,
Here is a link to bumper photos.
http://s807.photobucket.com/albums/y...mper%20Photos/
Wet and dry what grits and how many sheets to do the work? One bumper on corner is scuffed with scratches, in front bumper crack on top in two places, see ringed pictures. Also some rust on rear cills. How do I remedy these problems and what materials, products do I need to get, from Halfords or other motor factor.
Wing mirror needs tidying, replacement unit for other side needs painting. I have several sheets of good stout wrapping paper, thought much better than newspaper, that might allow bleed through, even if doubled up, fathing about trying to double up and stick down with masking tape. I have some Wickes 1 inch wide decorating masking tape, assume OK to use this.
All help and tips on this, much appreciated, I really havn't a clue.
Cheers,
Peter.
Old Mar 21, 2012 | 09:21 PM
Gaia's Avatar
Gaia
Default Fiesta Encore Bump;er Photos
That link was bad, I'll try again.
Yeah that seems to be working OK.
boeb
Jan 9, 2020 05:11 AM
gambo08
Feb 4, 2016 10:49 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
rsguy
44
Sep 29, 2015 03:29 PM
