doing the cutting out thing again?
Old Mar 19, 2012 | 09:50 PM
wedge07's Avatar
wedge07
Default doing the cutting out thing again?
driving home then just dies? starts up after ive stopped then 30secs dies. sounds like its idleing badly wen start it up after it died? so as it was idlein badly i opened bonnet had a mooch shook the ecu and it idled from bad to sound???????????
is the ecu fooked as sometimes it drives mint and sometimes i get random electrical faults?? ordering brand new OFAM tomoz so hopefully it all gets cured!!??
Anybody else had this problem???
Old Mar 19, 2012 | 10:02 PM
studabear's Avatar
studabear
I had a stop start problem years ago on a nova sr, it was the fuel filter.
Old Mar 19, 2012 | 10:11 PM
wedge07's Avatar
wedge07
ill get that changed asap cheers mate, only cheap arent they? thats one thing ruled out cheers
Old Mar 19, 2012 | 10:13 PM
studabear's Avatar
studabear
thats the way I look at it, if its a service item change it to rule it out and for peace of mind.
Old Mar 20, 2012 | 11:57 AM
lewis.philcox's Avatar
lewis.philcox
Could also be the halls sender in the Dizzy mines absolutely fooked at the moment car gets hot and shit hits the fan and im on a recovery truck lawwwl
Old Mar 20, 2012 | 05:06 PM
Rob_DOHC's Avatar
Rob_DOHC
My genuine advice would be to locate the source of your problem before installing a new ecu. It will save you sooo much time in the long run. You will also need a wideband lambda kit with an aftermarket ecu (if your mapping it your self).
I would have a check over of all the wiring, connectors etcetc, if its an intermittent thing
Old Mar 20, 2012 | 08:27 PM
wedge07's Avatar
wedge07
Just ordered my ofam, ill go through all wires too cheers. How much for the wideband kit n how do i istall that?
Old Mar 20, 2012 | 08:38 PM
obrutsr09's Avatar
obrutsr09
could be Fuel pump relay (pink one under dash drivers side), had this happen on my old rst
Old Mar 20, 2012 | 09:34 PM
sicosnutter's Avatar
sicosnutter
was my pink relay on mine,had melted under dash drivers side,also had problem with dizzy on another i owned when hot.
Old Mar 20, 2012 | 10:01 PM
project rs's Avatar
project rs
with you shaking ecu and it all going well i'd be inclined to look at the vacum hose going to it, make sure it's not trapped or being pinched somewhere and make sure it's not leaking too and is connected ok each end
Old Mar 21, 2012 | 06:26 AM
wedge07's Avatar
wedge07
Sorry lads, forgot to mention mine is running efi
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
155lee
Oct 24, 2015 11:11 AM
IainRS1700T
Sep 25, 2015 06:44 AM
cossirob
Sep 16, 2015 07:39 PM
hopper350
Sep 4, 2015 12:53 AM
