Water Cooling upgrade. Part 2. The GPU's and HUGE radiators are in!
Old Mar 19, 2012 | 05:03 PM
Stu @ M Developments's Avatar
PassionFords Creator
Default Water Cooling upgrade. Part 2. The GPU's and HUGE radiators are in!
Hi Guys,
I have been taking my cooling to its final step this weekend so thought it may be of interest for folks to have a bit of a reference topic as to how a few things work out.
The system:
Case: Corsair Obsidian 800D
Mobo: Asus Maximus Extreme IV - Z
CPU: Intel Core i7-2600K @ 4.8ghz
GPU: 3 x Sapphire Radeon 7970's running standard clocks (for now)
RAM: 16GB of Corsair Vengeance 1866MHz
HDD: 2x OCZ Vertex 3 Sata 6 SSD
PSU: XFX Pro 1250w Black gamer Edition
Cooling & Monitoring
CPU Block: EK Supreme HF Plexi EN
Radiator: 1 x EK Coolstream XT 360mm Copper Fins - Single Circuit
Reservoir: XSPC Acrylic Dual 5.25 with pump inside
Pumps: Alphacool VPP655 - D5 Pump
Rad Fans: 3 x Scythe Gentle Typhoon 1850RPM - AP15s.
Case Fans: 3x Corsair 140mm fans.
Coolant: Feser Aqua - Ultra Pure Water
Ok,
So what I propose to do is as follows:
  1. Run the NEW Aida64's system stability test for 10mins as it is now and got a screenshot.
  2. Install my new radiator and fans and repeated the test and got another screenshot to see what the extra cooling area does for the CPU (if anything).
  3. Installed my EK waterblocks on the 7970's and again, repeated the exact same 10min test.
  4. Run the same test again, but with no fans. (Passive)
The radiator being added is a Phobya Extreme Supernova 1260.
The 4 x 200mm fans being installed on it are the Cooler Master MegaFlow 200
If anyone has any usefull comments or suggestions I would love to hear them.
The first test is done and came out as follows.
As you can see, the CPU is being looked after very well with room ambients of 22C, and the 7970's core and VRM's are having a hell of a time, although its worth noting they never get quite that hot after an hour on battlefield, so god knows what Aida64 does to them!? One things for sure, it draws some power, its the ONLY test I have that gets these carsd that hot and draws over 1KW from the outlet!
Some pictures of the progress... [I]
200mm fans fitted to backplate.
3x EK 7970 blocks.
This rad is as big as my 24" monitor. LOL
2x 140mm NB pro fans to upgrade the 2 in my case while I am at it.
The missus helping me dry up a water spillage when I spat my dummy out.
Random parts shot.
The first card coming apart.
Ready for the block.
Block fitted.
Backplate fitted.
Dont wanna slip with a screwdriver round here!
3 cards ready to be fitted with bridge and links.
1st link fitted.
All built up and ready to install. Shockingly heavy.
The Loop. Not totally happy with this as its a bit untidy, will renew later.
More testing pics soon...
Had a small issue with Aida in as much as, I liked it so much I bought it, but the *beta* i dumbly downloaded it doesnt seem to recognise my 3rd card! Damn thing.
Still,
Got it all up and running and did some testing with heaven V3 / 3dmark11 etc and all seems to be working and benching as it should, so I have proceeded.
This test was run exactly the same as before, Aida 64 stability test for ten mins with fans all at full speed, and identical screenshots taken, so here we have it...
To say I am happy with the results is a huge understatement!
So, with such great results I figured the ultimate test was in order. No fans in the system running at all.
Totally passive and, more interestingly, SILENT.
Please note:
I havent made it clear that this system has retained the EK 360mm rad in the roof as well, so I have a LOT of rad surface area. And its working.
Some almost final images...
Old Mar 19, 2012 | 05:04 PM
The Aquaero system controller is now programmed as follows:
If the 1260 radiator inlet temp reaches 27 degrees fire up the 200mm fans at 20% speed.
This then ramps up at 20% every 1 degree until 30degrees at which point they run full speed.
If the water outlet into the reservoir sees 30 degrees water temps, we can assume the 1260 alone isnt dropping temps enough so the 3x scythe AP15s on the 360mm rad fire up at 20% but this time go to 50% at 31 degrees, 75% at 32 and full speed at 33 degrees.
The case fans both follow a similar curve, aiming to keep the case ambients below 28C.
All in all I am VERY happy, and for anyone interested in fan noise, the 200mm's really are silent unless you are within 12" of them.
The AP15s arent though. LOL
Old Mar 19, 2012 | 05:58 PM
Miller 3's Avatar
Miller 3
Very nice mate, but it also looks very expencive lol.
I realy hope it dose not have a wee wee on the carpit ha ha.
Old Mar 19, 2012 | 06:05 PM
I assure you mate, if the worst happens and it leaks, and all it wets is the carpet... I will be over the fucking moon! LOL
Old Mar 19, 2012 | 06:07 PM
Miller 3's Avatar
Miller 3
Fucking damn right lol
Old Mar 21, 2012 | 03:11 PM
Old Mar 22, 2012 | 08:13 PM
Well, I guess for now its finished.
Cpu is now running 4.9ghz stable with the cards at 1200 GPU & 1575 Ram.
Max recorded power draw now is...
Have really enjoyed building this, but now my CPU is holidng back the GPU's so its time to bide my time and await the outcome of the latest IVY bridge hardware.... then, I guess we start again, but for now, I am going to get some benchmarks done.
Old Mar 22, 2012 | 08:18 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
If you need any more rads, I've got 2 brand new Swiftech ones, a 220 and a 320, also a micro-res and some tubing, all bought when I was going to WC my pc, shame I'm skinter than skint and can't afford to now. Although, I doubt you'll need it for that pc.
Old Mar 25, 2012 | 06:50 AM
Me too... LOL
Old Mar 25, 2012 | 07:51 AM
danneth's Avatar
danneth
TORQUE!
Epic stu, love them temps for what your running
High res pics of some games please
Old Mar 26, 2012 | 12:50 PM
Borrowed this from another forum I use to save me the bother... they get the point across.
So here's Some examples of using 2.75GB of VRAM! (Not System Ram...) In Crysis 2 maxed to the hilt in DX11 and Forced in NV control Panel to use 16x AF and 16XQ CSAA @ 2560x1600. Running @ 60FPS.
Old Mar 26, 2012 | 04:24 PM
danneth's Avatar
danneth
TORQUE!
surely there's 5.0ghz in there
Old Mar 26, 2012 | 04:26 PM
I currently run her at 5.4ghz for benchmarking mate but it requires a lot of volts and heat.
For day to day running she stays around 4.8ghz now.
Old Mar 26, 2012 | 04:34 PM
danneth's Avatar
danneth
TORQUE!
Whats Drivers you using for the GFX? ones that came with the cards or aftermark ones?
Old Mar 26, 2012 | 10:47 PM
Driver = latest AMD Beta and Afterburner to overclock them.
Old Mar 27, 2012 | 09:12 PM
fatmike's Avatar
fatmike
Nice rig Stu. Currently running an watercooling rig myself, but currently only on the cpu. Just about to add my card into the mix aswell (6990). JUst out of curiousity, how well do 3 gpus work?? I've heard many mixed results when you triple stack.. Do you think they definitely justify themselves and have you ran into any issues with them?
ps love the external rad haha
Old Mar 27, 2012 | 10:11 PM
Hi Mike,
hope your enjoying the planning mate, thats the part I like best actually.
In days gone by, scaling for SLI and Crossfire could be anywhere from good to terrible, but nowadays its pretty damn good, with the latest generation cards like these often achieving 100% scaling upgrade per card.
If your interested in what yours can do, try popping "6990 Crossfire scaling" into Google and your bound to come up with some comprehensive reviews as its a great card that has sold well.
Old Mar 28, 2012 | 09:25 AM
Jay,'s Avatar
Jay,
Sponsor
Shit Stu are building your own skynet there
Old Mar 28, 2012 | 09:43 AM
RONNIE AMIS's Avatar
RONNIE AMIS
Yikes!!! That looks impressive. Havnt got a Clue about anything you have written about but it sounds good.
Old Mar 30, 2012 | 10:25 AM
Its less complicated than your race car plumbing that James is shouting and swearing at as we speak. LOL
Old Apr 9, 2012 | 01:10 PM
foreigneRS's Avatar
foreigneRS
Testing the future
do you put just tap water in there, or some kind of inhibitor as well to stop bacteria growth and clogging up?
Old Apr 9, 2012 | 04:21 PM
Hi Nick, you use a distilled water with a corrosion inhibitor and sometimes a UV dye to make it glow if so required. I prefer UV pipes as the dye taints everything it touches which I pesroanlly dont want in my expensive parts.
Old Apr 9, 2012 | 07:09 PM
foreigneRS's Avatar
foreigneRS
Testing the future
good to hear, wouldn't want it going all maky on you Stu
Old Apr 9, 2012 | 07:21 PM
RS500/364's Avatar
RS500/364
Sure i cant see what size the SSDs are !
120gb around Ł100 at min
Old Apr 9, 2012 | 09:13 PM
2x 240gb and 1x 120GB.
Old Jan 1, 2013 | 04:59 PM
Since I had a few days off ive been playing, so have upgraded the monitors to 120HZ BenQ gaming versions, added another SSD, a 512gb Vertex 4, swopped the ram out for 8gb of 2133 stuff and changed the processor for a 3770K.
No doubt I will now spend the next week looking at BSOD's and HWbot screens, so for now, Call of duty calls.
Old Jan 2, 2013 | 04:51 PM
Eagle's Avatar
Eagle
Super Moderator
so hows the new i7 working ?
must be seeing a better result i presume.
any reason why you didnt go for that in the first place ??
155lee
Sep 6, 2016 11:10 AM
155lee
Oct 27, 2015 04:55 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
cossirob
Sep 3, 2015 09:17 PM
StephTell
Sep 2, 2015 06:31 PM
