conductive adhesives
Old Mar 19, 2012 | 02:10 PM
FastFordChris's Avatar
FastFordChris
Default conductive adhesives
The wire has come off the rear heated screen so i've been looking for a conductive adhesive but not had much luck, tried a few different ones now and theyve either not stuck to the glass or melted off as soon as you turned the heat on.
Anyone got any recomendations for a good one to use?
Old Mar 19, 2012 | 02:54 PM
fraser9764's Avatar
fraser9764
You can solder them back on if you are very carefull. I wouldnt recommend it but it can be done.
Old Mar 19, 2012 | 03:59 PM
FastFordChris
the problem is the joint is inside the bodywork, so access to its very limited so i wouldnt want to risk it.
Old Mar 19, 2012 | 07:06 PM
wayne dowling's Avatar
wayne dowling
Iv used chemical metal to bond heated screen contacts back on
Old Mar 20, 2012 | 02:18 PM
FastFordChris
is chemical metal conductive though??
Old Mar 20, 2012 | 02:20 PM
wayne dowling
Yes mate iv done a few and they've worked
Old Mar 20, 2012 | 03:19 PM
FastFordChris
cheers, i'll give it a go then
TPM961
Jan 15, 2018 10:50 AM
Vacuman
Sep 22, 2015 12:09 PM
muz
Aug 16, 2015 12:57 PM
morto
31
Sep 19, 2006 06:45 AM
fitzy_88
Apr 4, 2006 08:15 PM
