VXR INJECTORS (Again... Sorry)
hi lads, gathering a few bits for the s1 ready for the imminent rebuild. been looking for some Astra vxr injectors and a part number of what i need to try getting them through work. saw a set on egay with rail complete. just wondered are these right and correct 480 ish cc?
http://www.ebay.co.uk/itm/Vauxhall-Astra-VXR-Fuel-Rail-Injectors-Z20LEH-Z20LET-/300676001109
thanks in advance.
thanks in advance.
beiges are 220-30 cc and vxr are 480 cc. think i`ve managed to source out a gm part number for the rail and 4 injectors. just waiting for it to come in on stock order. bout £115 from vauxhall new. karlos g got 230 bhp out of them on his cvh i would`nt have though beiges could do 200bhp as i found out my cossie blues 311cc weren`t up to it either??
Greys are close to 500cc/min i think and im sure greens are around 380cc/min
Yeah im confused by the beiges, mine flow tested at 238cc/min... And i see cvh's and zvhs running 200-230bhp on a regular basis? Surely the vxr's at 440cc can push nearer 280-300bhp?
Wedge - whats your spec..
Fiesta rst engine 1600 cvh
Lightened and balanced bottom end
Beiges
Ofab
bayjoo chip
-31 actuator
t3 hybrid
Full front mount
lsd box
14psi
Not sure what parts are inside engine apart from steel rods n forged pistons, i just put engine n box in car together lol
Beiges
Ofab
bayjoo chip
-31 actuator
t3 hybrid
Full front mount
lsd box
14psi
Your probably best off using what you have, and seeing how far you get... is your mapping your self this isn't a big deal, but i can see why people wouldn't want to do this if it cost £3-400 for a remap/setup with each injector change....
Thats good power for the spec, im running a similar spec but with ofam and beiges... Hoping to get 200bhp from the beiges and then substainially more from the vxr injectors.
Is there any other injector that can get upto the 300 mark? Plus im not sure wat clutch i got in but it keeps breakin cables n the rachet. Im after a paddle clutch if anybody knows of a decent one? Not doin that yet though lol
all i got to do is have my ms put back to use high z injectors and bang. off we go. heard that they can control high z injectors with driver fitted. might drop phil an email?
all to do with how efficient an engine is bfsc or something.lol. cvh are very low so compared to a more efficient engine the need bigger injectors for equal bhp or somthing like that? also depends on fuel pressure higher fuel pressure higher cc/min.
ms1 v3 mate. phill ringwood built it with the peak hold driver for my cossie injectors i already had. low z. made a school boy error presuming dark blues could do 200 in cvh as they can do 250 in a cossie. 230 is the max i'd push my 1.6 to and im getting the vxr injectors cost so 80 quid. makes sense instead of 200 for dekas.
cosworth greys would be a sound choice for any one wanting low impedance injectors and power potential for 300bhp.
Rob,
Im pretty sure rick would have mapped crazycages car, but im sure he will have used greys at some point, drop him an email etc, if your close by and need your car mapping I wouldn't have any concerns with using him
i'll be sticking with vxrs if they turn up correct rob was just saying im sure someones used them. lol. gonna have a bash myself but good to know theres guys about if you get stuck. the main problem i had was the idle valve control. bloody nightmare.
My Focus is running beige Volvo T5 2.3T injectors. Part number is 0280155766. They are 355cc/min injectors and can run upto 300bhp apparently. May not be suitable for S1 but they could be
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
