actuator
What is the difference between a standard and a -31 actuator?
I appear to have a standard actuator on my car now but it was wound right in and has side to side play.
Is it worth upgrading to a collins -31 actuator whats the benefits?
a worthwhile upgrade. its stronger spring allows the boost to be more stable, something of an issue with a tired old unit. -31 equates to a minimum preload of about 10psi irc. mine has been much better since swapping my actuator to a -31.
JK12
33
Apr 26, 2021 12:09 PM
