Help again pls
Old Mar 18, 2012 | 09:04 AM
Omitsean's Avatar
Omitsean
Default Help again pls
Hi just bought a manual boost control for my rst and have an animal vavle been reading on here it is possible to run an on off to the animal vavle and control boost that way is that the best way our should I use the manual boost control car is currently running 23 psi with unlimited ecu thanks
Old Mar 18, 2012 | 10:45 AM
beaver rs 88's Avatar
beaver rs 88
in the garage
Personally I'd stick with the amal valve mate there better than a manual boost controller as they don't seem to spike.
Old Mar 18, 2012 | 10:48 AM
Sjieter's Avatar
Sjieter
If you are going to use another boost controller , i think it's best to just use 1.
So if you are going to use the "manual" boost controller leave the AMAL valve disconnected.
Most on here will say it is best to keep using the amal valve and get it rejetted.
Got no idea what the best is , but i'm using a turbosmart boost T bleedvalve until i get the amal valve rejetted.
Old Mar 18, 2012 | 10:52 AM
Omitsean's Avatar
Omitsean
Is it worth putting the animal valve on a switch so I can turn it off and on don't real won't to be running 21psi
Old Mar 18, 2012 | 10:54 AM
PhilCook's Avatar
PhilCook
Amal valve
Old Mar 18, 2012 | 03:28 PM
Omitsean's Avatar
Omitsean
And I take it to turn down the psi I turn the accuter in
Old Mar 18, 2012 | 04:44 PM
Sjieter's Avatar
Sjieter
Sorry for correcting you but it drives me mad..
It is an AMAL valve and an ACTUATOR.
If you disconnect the plug on the amal valve it will lower the boost , but then you would always have to open the hood and disconnect it or plug it in..
Better to buy a boostcontroller with different stages..
Old Mar 18, 2012 | 07:33 PM
Omitsean's Avatar
Omitsean
Cheers for the help will look in to one
martinmilne
Oct 18, 2019 02:18 AM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
cozzy jeff
Aug 14, 2015 05:46 PM
Porkie
21
Dec 16, 2004 10:23 PM
woodz77
Sep 20, 2004 04:45 PM
