knocking noise while driving??
Old Mar 17, 2012 | 08:17 PM
chezrsturbo's Avatar
chezrsturbo
Default knocking noise while driving??
hi hope anyone could help when im driving my s2 turbo there is a knocking noise like a driveshaft knock ive replaced both shafts and the gearbox and it is still doing it does anyone know what it could be?? thanks
Old Mar 17, 2012 | 08:31 PM
boy-racer-1's Avatar
boy-racer-1
give the engine a rock about by hand if you hear any slight nocking then its most likely an engine or gearbox mount
Old Mar 17, 2012 | 08:36 PM
chezrsturbo
ok mate the gearbox mounts looked fine when i changed the box
Old Mar 17, 2012 | 08:39 PM
gouch1's Avatar
gouch1
i would say gbox mount even if it looks fine it can still have play under load
Old Mar 17, 2012 | 08:40 PM
chezrsturbo
ok buddy ive got 2 more il try them tomoz
Old Mar 17, 2012 | 08:41 PM
boy-racer-1
they might look fine mate but you will definately need to check them still, ive had new mounts on for 2 months and were nackered again yet still looking fairly new, just give the engine a good pull about in the bay, the only noise you should hear is yourself struggling to pull it about and the possible handbrake/suspension creak where you are trying to pull it about so much, any slight sound of nocking is more then likely going to be engine mount or gearbox mount failing that start looking at driveshaft bearings and wheel hub bearings or suspension top mounts
Old Mar 17, 2012 | 08:47 PM
chezrsturbo
ok mate gonna try 2 new mounts on tomoz
Old Mar 18, 2012 | 05:59 PM
chezrsturbo
Found the problem! Wheel bearing lol was no play init or anything tho but thort id try one to eliminate it and it stopped the knocking thanks for your advice
Fiddy
21
Sep 29, 2015 06:10 PM
Botts
Sep 22, 2015 02:04 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
talon1
Sep 15, 2015 10:27 AM
Flateric_2002
Sep 15, 2015 08:41 AM
