omex 600 or megasquirt?
Old Mar 9, 2012 | 06:57 PM
wedge07's Avatar
wedge07
Default omex 600 or megasquirt?
hi everybody i know this questions prob been asked but im ready to upgrade from OFAB.
just managed to get a hold of some green 803s , now i just need to know what ecu setup?
got forged pistons and steel rods etc and want less lag, more boost, more boost control etc
just not sure which road to go down now lol, need everybodys experiance and which is better for money as omex is twice the price of megasquirt?
cheers guys
Old Mar 9, 2012 | 07:09 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Either is an acceptable solution if properly mapped.
Just make sure the megasquirt is properly assembled, there are still some nasty home built examples kicking around secondhand etc.
Old Mar 9, 2012 | 07:27 PM
wedge07's Avatar
wedge07
cheers mate, i can do the wiring my self as im a sparky by trade , and theres nowt worse than a messy engine bay and loom lol
i take it they come with wiring diagrams? they easy to build yourself?
Old Mar 9, 2012 | 07:29 PM
luke19790_3's Avatar
luke19790_3
efiextra or you can get OFAM which is handy if you have a OFAB setup because it plugs in
Old Mar 9, 2012 | 08:02 PM
wedge07's Avatar
wedge07
what are these? not heard of them? they much different and do they do the same thing, not wanting to spend loads as trying to sort out two other cars lol.
just need a better ecu for more power and control
Old Mar 9, 2012 | 08:26 PM
mk1turboestate's Avatar
mk1turboestate
ofam all the way mate http://www.boostmonkeys.co.uk/products.html i have one pm rob_dohc on here for more info
Old Mar 9, 2012 | 08:27 PM
mk1turboestate
its a ms ecu that plugs into your loom
Old Mar 9, 2012 | 08:33 PM
TommyB's Avatar
TommyB
Boosted 122 cu in
What's your budget for a ECU?
Old Mar 9, 2012 | 08:47 PM
Rob_DOHC's Avatar
Rob_DOHC
Cheers for the links guys,
My honest advice (if you aren't mapping this your self) would be to go with what ever your tuner prefers. If they are happy with megasquirt then great, if not then go Omex.
In certain respects megasquirt 2 is more advanced than the omex 600, however in the real world every thing depends on how well megasquirt is built, 99% of megasquirt problems come from iffy CPS wiring and bad DIY ecu builds (which as chip says you will find lots of 2nd hand).
Which ever you do make sure you get a build thread up
Rob,
Old Mar 9, 2012 | 09:10 PM
wedge07's Avatar
wedge07
cheers for the link
that looks like the road i may go down, will my green 803s work with this?
i was looking around 4-500 quid but my tuner wants me to go down omex 600 n said its gonna be around the £2,000 and more
is it easy gto map myself, considering ive neva done it in my life, will i pick it up easy enough and are there any guides?
cheers
Old Mar 9, 2012 | 09:22 PM
Rob_DOHC's Avatar
Rob_DOHC
Have a good read of this http://www.megamanual.com/ms2/tune.htm
You will want high impedance injectors, VXR injectors can be bought cheaply (sub £100).
Mapping is easy to pick up your self, mapping things safely takes a little practice (but is perfectly learn-able), its really an experience thing, you won't screw the last 10% out of your car that a good tuner with a dyno would, but with some learning you will have a good safe car thats nice to drive.
There are more and more tuners/individuals who are feeling happier about tuning megasquirt these days too, so depending on what other tuners are close to you that may also be an option.
Maybe your tuner would be okay with you picking up a 2nd hand omex which you could fit before giving him the car? Any good tuner would be able to map MS though tbh, they just don't like fixing the millions of fuck ups that badly built ones normally have...
Rob,
Old Mar 10, 2012 | 11:08 AM
wedge07's Avatar
wedge07
Ok cheers well i get paid again soon so might just order the OFAM and go from there. Id love to be able to tune my own car . Vxr injectors better than 803s? N they a straight fit ordo i need mod a fuel rail?
Old Mar 10, 2012 | 11:10 AM
Chip's Avatar
Chip
What tuner is that?
Old Mar 10, 2012 | 01:04 PM
wedge07's Avatar
wedge07
mikeanics mate, thats to do the lot himself! What tunees will touch megasquirt or ofam?
Old Mar 10, 2012 | 07:05 PM
DazC's Avatar
DazC
Omex gets my vote!
You'd have to sell you 803s if you use Omex though as they're low impedance injectors where as the Omex uses high impedance injectors.
Old Mar 10, 2012 | 07:09 PM
Chip's Avatar
Chip
Originally Posted by DazC
Omex gets my vote!
He can add a peak and hold box or get a bit pikey and add resistors.
But a set of high imp would be a better idea I agree.
Old Mar 11, 2012 | 02:30 PM
rsmark86's Avatar
rsmark86
Ian and Matt at power engineering could do a good deal on omex fitted and mapped
Pm guzzler on here
Old Mar 11, 2012 | 06:51 PM
DazC's Avatar
DazC
There is that option but I'd sooner just buy some injectors rather than go through the effort of peak/hold drivers or resistors. Less hassle and work involved.
Old Mar 12, 2012 | 09:39 PM
wedge07's Avatar
wedge07
im going for the OFAM, next week im ordering. what injectors then? ill sell the 803's lol
Old Mar 17, 2012 | 06:10 PM
wedge07's Avatar
wedge07
Just been thinking, wats the point in astra vxr injectors, wen beiges can get 230-240 bhp the same limit as vxr injectors?
Ordering ofam tues getting excited lol anything else i need get???
Old Mar 17, 2012 | 09:37 PM
russ rs's Avatar
russ rs
Thought VXR are 420s
Old Mar 17, 2012 | 10:37 PM
wedge07's Avatar
wedge07
I read somewhere vxr injectors are only good for that amount. I maybe wrong. I need to find out if anybody knows
Old Mar 18, 2012 | 11:17 PM
Rob_DOHC's Avatar
Rob_DOHC
I believe they are 480cc/min, ask karlos_g, he ran them for a while.
Rob
Old Mar 19, 2012 | 07:57 AM
Rogeyboy's Avatar
Rogeyboy
After a quick google up i think they are 440cc...
Im on beiges atm, and intend to max them out before changing to the vxrs.
Ive seen various cars running 210-230bhp on the beiges (240cc/min) so i don't know whats what with injectors tbh!
Old Mar 19, 2012 | 07:31 PM
wedge07's Avatar
wedge07
Ok cheers, i think ill do the same lol
Old Mar 19, 2012 | 09:04 PM
luke19790_3
don't think beige injectors will do 230bhp, maybe they're running them at a higher pressure? Is 3 bar is standard on them?
IainRS1700T
Sep 25, 2015 06:44 AM
dombanks
Sep 21, 2015 08:38 PM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
Tank Mike
Sep 14, 2015 03:56 PM
