Escort Stalls When Warm While Driving
Hi everyone,
The Car: 1986 Escort, 1.9L, Carbureted, 3 speed Automatic with about 66,XXX original miles on it.
The Symptoms: Car starts fine when cold (except this morning, it was a little more stubborn). We can drive it around for about 30 minutes. We can go to several stores, shut it off, turn it on, and all will be well until we've hit about the about 30 minutes of total actually driving around. Then, without warning, we can start it up (with no problem), drive away, and in less than a 1/4 mile, (even while accelerating, rapid accel or slow accel doesn't matter) it starts to spit and sputter, then stalls out. Once this happens, it won't restart without using starting fluid, and sometimes even that's quite an ordeal, as we have to keep spraying it and revving it until it decides it's going to stay running, which can take a good one to two minutes, give or take. Then it's fine.
Obviously, it has spark if it will start with starting fluid. It just acts like it has no gas, or it's starving for fuel.
When it finally restarts, the exhaust is thick like the car has flooded.
Once we go through this running fine, stalling, finally getting it restarted, it seems to run just fine again and doesn't stall out. This happens once a day. (Probably because we get frustrated with it and park it at home, so we've not had it happen twice in a day.)
If you drive it over 30 minutes, but don't shut it off, it runs normally, but once you shut it off (after that 30 minute driving period) then restart it is when the symptom(s) occur. It's not overheating, and there are no other problems that we've identified... just this mystery problem.
What We've Done:
1. Changed the fuel pump (mechanical)
2. Changed the fuel filter (which is attached to the carb)
3. Cleaned the carb with carb cleaner
4. Checked for and corrected vacuum leaks (except one, but that vacuum line is plugged off)
5. We've recently added SeaFoam to the gas tank (at 3/4 tank) to run it through the fuel system.
6. Disconnected the Idle Stop/Idle Fuel Shut-Off Solenoid (but the car wouldn't run well at idle, so we plugged it back in) trying to rule that out as a possible problem.
7. Engine has had a recent tune up.
Things we've considered:
1. Attempting to adjust the dashpot, but the area is so tight to work in we've decided to leave it alone for now.
2. Vapor lock? The fuel lines run right across the top of the engine, directly under the breather... but we question this as a problem since it's pretty cold outside right now.
Once we'd changed the pump and filter, we were kinda excited because it looked like that was the problem, but then... BAMM! The problem was back the next day.
When the car is running right, it runs really well, nice and smooth, then this happens without warning. I'm about at wits end with this thing.
Thanks to those who can help us with this thing.
What We've Done:
not really in the right country for advise on the american 1900 ho engine pal. No-one over here would have that engine setup apart from a rare few to offer experianced 1st hand advise
Get on the american forums for help with this.
CabrioTurbo
Aug 1, 2015 11:04 AM
