Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
failed mot on emmissions
Old Mar 7, 2012 | 07:30 PM
carl74's Avatar
carl74
Default failed mot on emmissions
Hi
I have a 1.6 zetec se petrol which failed mot on emmissions, its had a new breather pipe and lamda sensor which have made no difference. I was told it is burning oil a bit so could be the cat also read the ecu could be at fault. any help on this? When revved up to 3000rpm its a bit up and down instead of constant so they cannot get an accurate reading.
Old Mar 7, 2012 | 10:22 PM
Mattfletcher's Avatar
Mattfletcher
worn pistons/valves??
Old Mar 8, 2012 | 07:38 AM
oldford's Avatar
oldford
Have you got any readings from the emissions?
CO, CO2, O2, HC, Lambda value?
Old Mar 8, 2012 | 10:19 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Could coil pack cause high emissions? Any lights on on dash
Old Mar 8, 2012 | 11:04 PM
GVK.'s Avatar
GVK.
Could be anything. Base engine fault causing the smoking.
As oldford has posted, need to see the results from the emission test really.
Get fault codes read, lambda sensor values checking on live data for a start.
I had a car (mk3 Golf GTI) fail with very high emissions (10% CO) turned out the fuel return to the tank was blocked and the fuel pressure was 6 bar.
GVK.'s Avatar
GVK.
Could do if it's misfiring!
Old Mar 9, 2012 | 05:15 PM
Greasenuts's Avatar
Greasenuts
The hunting ("a bit up and down instead of constant") could be caused by an air leak on the inlet (after the throttle body, before the manifold meets the head). This could affect the emissions....!
With the engine ticking over get yer head under the bonnet and listen for a hissing noise, if you think you hear one spray some wd40 around where you think the noise might be and see if this affects how the engines ticking over.
Just an idea, hope it helps!
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
