Rebuild
Old Mar 7, 2012 | 01:13 PM
Omitsean's Avatar
Omitsean
Default Rebuild
Won't to get my engine rebuilt and cleaned up any ideas were to go to I live in Surrey pls help
Old Mar 7, 2012 | 04:04 PM
darrenb16two's Avatar
darrenb16two
Is the engine out of the car? Whats wrong with it? Whys it need a rebuild? Whats your budget?
Old Mar 7, 2012 | 05:16 PM
Omitsean's Avatar
Omitsean
Engine still in car and running just not had it for long and would like it done for peace of mind and not sure on budget no idea how much it cost
Old Mar 8, 2012 | 10:14 AM
Rob_DOHC's Avatar
Rob_DOHC
really depends upon spec, if you just want a standard rebuild and your engine doesn't need much machining work then it could cost 350 in parts and another few hundred for labour so Ł500,
However, if it has badly worn bores, worn crank journals, a knackered cam (and probably a worn oil pump) etcetc. You would be looking at Ł800 in parts alone for a standard(ish) build.
I would always recommend having a reputable place blueprint, balance and build your engine, and as a very minimum you should install ARP con rod bolts.
Good luck
Rob,
Old Mar 8, 2012 | 10:15 AM
Rob_DOHC's Avatar
Rob_DOHC
Where in surrey are you btw?
Old Mar 8, 2012 | 12:40 PM
Omitsean's Avatar
Omitsean
In Epsom. has had a lot done already like arp rods if you are locial pls pop round and have a look you mite be albe to help me out
Old Mar 8, 2012 | 06:31 PM
Rob_DOHC's Avatar
Rob_DOHC
I live in Sutton, the very first job i ever had was at halfords in Epsom
What actually makes you think it needs a rebuild?
Rob,
Old Mar 8, 2012 | 07:32 PM
Omitsean's Avatar
Omitsean
Nothing just would like to know it has been done proper and to clean the engine up real it's the first rst I have owend and just won't to be safe snd not mess it up straight away and every one I know noes nothing about these cars So can not get any one to give it a once over fir me
Old Mar 8, 2012 | 08:14 PM
blackbeautyzetec's Avatar
blackbeautyzetec
I live down the road in morden and a few guys live in Mitcham if you ever need a hand ect
Old Mar 8, 2012 | 08:24 PM
Omitsean's Avatar
Omitsean
Could do with meeting just so you could have a look over car for me if possible got a few probs
Old Mar 8, 2012 | 09:17 PM
blackbeautyzetec
Still the problems up on here mate. Most people are very helpful.
bobsworth
77
Mar 24, 2016 09:30 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mc5506
Oct 5, 2015 09:57 PM
coscor86
Sep 20, 2015 01:21 PM
