GT30 turbos and breathers? what breather do i need? HELP
I have updated my resto thread and you can see with my GT3076r turbo fitted there is no room for my spec r oil breather on the inner wing - so what are people using on their cars?
Quick pics below
Quick pics below
I've got the old cylindracal one bolted on the bulk head panel next to the battery but for the life of me I can't remember the name of it
its either that I've not used the car for months or I'm getting old
Luciano
Luciano
ive got one of them too jimbo - a bailey breather/seperator thingy but wanted one like the above as its what my old car had.
Will get a pic of my 3dr engine bay up in a mo.
Is that bailey breather enough for my engine spec?
here is an engine bay pic off my old 3dr - i have a similar round bailey breather thingy as shown in the pics at the back of the engine bay - is this sufficient for my current spec engine?
Check this thread out Ran, some good info there -
https://passionford.com/forum/genera...ml#post5438563
I will remove the spacer and see how things fit then
cheers
ran
Before you sell the block make sure you have enough room between the compressor housing and the manifold (the base of the comp housing where it's near the manifold)
You may be able to cut the spacer in half to make clearance better
With the .60 A/R you shouldn't need one but.....
I even have a 500 heatsheild in their too but it's tight
ive asked my mate to remove the spacer and see how things fit - he states it will move the turbo closer to the head so will have to see how we get on - otherwise im gonna sell the spec r tank
