1.8 MkII Focus knocking noise nearside front
Old Mar 6, 2012 | 10:11 PM
m00se's Avatar
m00se
Default 1.8 MkII Focus knocking noise nearside front
Hi all, hope someone can help...
I have a rumbling/knocking sound coming from the front nearside wheel on my mk II focus. It's loudest when going fast, and much louder when turning right. Hardly any noise when turning left. Going round roundabouts, for example, it gets louder as I'm going round, then gets quieter as I turn off. Going in a straight line it's there but not as loud. There is a slight judder associated with it coming through the steering wheel.
When stopped I have had it on full lock going round in circles and again I can hear it when turning right but it's much softer than when I'm travelling at speed. Going over bumps doesn't make it louder.
I can't see anything obviously wrong with the car when I've had a gander but then again I don't have any clue what to look for to diagnose this. I'm guessing CV or similar...?
Any thoughts? Any help would be really appreciated... Thanks in advance.
Old Mar 6, 2012 | 10:19 PM
GVK.'s Avatar
GVK.
Sounds like wheel bearing.
Jack it up and turn the wheel as fast as you can, if you can feel vibration on the coil spring it will be the bearing at fault.
edit - if it's more of a 'clicking' noise on full lock it could be an outer CV.
Old Mar 6, 2012 | 10:55 PM
m00se's Avatar
m00se
I'd hoped it wasn't the bearing as it hardly does it at all when steering left. Of course, I could be wrong because I know less than 0 about these things
Will get it up on the jacks tomorrow. If it's the bearing, is that a horrendous job? I'm fairly handy...
Old Mar 6, 2012 | 11:59 PM
GVK.'s Avatar
GVK.
When you steer left it takes the weight off the left wheel.
Bearing and drive flange needs to be pressed out/in on hydraulic press
Old Mar 7, 2012 | 05:44 AM
m00se's Avatar
m00se
Makes sense. Thanks a lot, will have a look.
Old Mar 7, 2012 | 06:28 AM
Bailes1992's Avatar
Bailes1992
That was my nackered bearing!
Also if you grab the wheel at 3o'clock and 9o'clock you should feel a little play.
Then do the same at 12 and 6 O'clock.
Old Mar 7, 2012 | 05:35 PM
GVK.'s Avatar
GVK.
Noisy bearing won't always have play in it.
Old Mar 7, 2012 | 06:14 PM
dingla rs's Avatar
dingla rs
its a wheel bearing as when you turn the oppesite way the nose gos ,garage job im afraid unless you have a mate with a press to get old and new bearing in
Old Mar 14, 2012 | 02:18 PM
m00se's Avatar
m00se
I have rung round a few garages locally and the prices are more than what I would pay for a press (130quid) and the bearings (55 quid) and to do it myself! Tempted, until I came across a place selling the bearing and the hub as a single unit for this model (http://www.ebay.co.uk/itm/ford-FOCUS...item1c1f894393).
This would presumably just bolt on as a unit in place of the old hub and save me pressing the new bearings in and out, no?
Thanks guys
Old Mar 14, 2012 | 02:34 PM
Fordmad!'s Avatar
Fordmad!
Id make sure it is a bearing before buying anything. Sounds like it is but could be cv joint.
Id jack the car up and just grab the wheel and see if theres any play there just to eliminate any other problems!
Old Mar 26, 2012 | 11:52 AM
m00se's Avatar
m00se
No play in the wheel when up on a jack. Not particularly noisy to spin it round either (like the one in the video was). Could still be a bearing? The front discs and pads could do with renewal though, could it be just that?
Tempted to take it to Kwik Fit and get them to stick it on a ramp then just make my excuses and bring it home and do it meself!
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
malkiemac3579
Jul 14, 2017 12:10 PM
C2 MAK
Aug 20, 2015 09:46 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
