focos 4x4 its home
as one the mods kindly deleted my last thread
he may deside to delete this one as he likes me
its a focos to anyone that not seen the build before
AG MOTORSPORT SHELL going to be 4x4 for now
really carnt be bothered to upload 4 years worth of pics so here few
iv missed 2000 pictures off of the build as it would take me a week to put them all back up
at the mo im waiting to hear back bout some parts so i can send motor to get build at boro big thanks to matt lewis for new oil pump an few parts to do motor build also andrew g for selling me some apr head bolts
few more the rear end and 300brake upgrade should be going in thursday nite for last time and fuel tank ,
the mod desided i shouldnt have changed my thread title and showed to much work on other cars is why he deleted it
front brakes
rear upgrade the spacer is welded washers for now
front brakes
Nice to see that your still building it Andy
I thought you'd sold up and id gained a dash2
Think you should of maybe been warned or had your title changed.
But to just delete your thread after 4 years is a bit rough
Hope they put it back on for you.
painted some more bits up after work t day as the beam going back in tomro nite ,droped the prop so repainted that
not tryed the upol paint before from auto jumble, seams to be good paint .but never seen a 2ksolid metalic silver before tho
. i need some 17mm spacers for rear end but will use the welded washers for now
redone the shafts aswell
painted a couple more buts as rest were dry me brake brakets for rear and beam mounts ,also got the few bits for clutch conversion ,will finish me diff mount off t mro eve ,as im not paying 120quid for some thing i can make
had too me good mates round for a lift in with the rear end ,bout time they did something
didn't start well i droped me diff
an broke the casting on the corner .we did get the rear end in and run the braided line to the t piece at the rear of car .also finished diff mount just got to make the washers for each side . can anyone tell me the thickness the spacer for prop to body is supose to be ?
managed to get the drivers side rear finished last nite ,i couldnt do the passenger side as fat knacker an jls desided to put dust shield on wrong way round.
painted diff hanger and run the rear brake lines,need order some more pipe to finish passenger side front
made me diff mount with this bent out of one piece
gna have turn down the inside of this a bit as its not fitting flush
