not clutch pin in gear box
can anyone help got AA out and its as if car staying in neutral so either new gear box or pin in gear box the car is a mondeo st24 v6 2.5 when the car is started i can select all gears let the clutch out and the car doesn,t move just revs any help appreicated thanks lads
Not info there buddy.
Need car,preferably what gearbox etc or even engine size would help.
I've seen this happen before on a jag that used the mtx75 box and it's pretty easy to cure,there's an inspection plate under the gear selector and a bit of fishing with a magnet got it out fine.
Assembly is reverse of removal!!!
TPM961
Jan 15, 2018 10:50 AM
