Mk1 FRS Engine...
Old Mar 4, 2012 | 09:09 PM
KW-rscos's Avatar
KW-rscos
Default Mk1 FRS Engine...
Looking to fit a Mk1 FRS engine into my Mk6 Escort GTi, It is currently running a 2.0 Mondeo silvertop, but will I have to modify the mounts to chuck the later FRS engine in to the bay? also what other issue might I need to address?
CheeRS
Old Mar 4, 2012 | 09:14 PM
rsmark86's Avatar
rsmark86
Engine mount is the same
Things to look at
Gearbox? Unless you mod everything to fit the frs box
Then clutch and flywheel
Exhaust
Hoses
Aux belt to ditch air con
Fuel system
Loom
Cooling rad and fmic
Would be a cool car done
Old Mar 4, 2012 | 10:02 PM
KW-rscos's Avatar
KW-rscos
excellent, just what I was looking for, thank you sir!
Old Mar 4, 2012 | 10:16 PM
rsmark86's Avatar
rsmark86
What box you going too use? Would be better to get the frs box in there mate
Also decat down pipe, actuator, fmic, airfilter and exhaust manifold and proper remap will see 300bhp?
Old Mar 5, 2012 | 07:17 AM
SteveB's Avatar
SteveB
Engine mount on the silvertop is different to blacktop
Old Mar 5, 2012 | 07:43 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
yes, the engine mount is slightly different to the silvertop.
A few mins with a welder and you'll be sorted.
i too recommend a focus rs box, or an rs2k one as you can get shafts to fit off the shelf for that then
whack a diff in and you're away.
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Sep 28, 2015 10:05 AM
Tank Mike
Sep 26, 2015 08:07 AM
