saph overboosting ?
Old Mar 4, 2012 | 11:04 AM
rich123's Avatar
rich123
Default saph overboosting ?
i cant seem to get my boost to come down its peaking at around 28psi should be peaking around 21-22 something like that,its running on bleed valve but thats turned all the in and ive turned the actuator down aswell but makes no diffrence
any ideas
Old Mar 4, 2012 | 11:08 AM
pee vee's Avatar
pee vee
you only recently put the bleed valve on?? sure you got it the right way round?
Old Mar 4, 2012 | 11:12 AM
rich123's Avatar
rich123
i think lol sure its turn in for less and turn out for more i think lol
Old Mar 4, 2012 | 11:14 AM
pee vee's Avatar
pee vee
yeah but i mean have you got the pipes round the right way.
the one from the turbo housing should be the one that the screw pushes straight down onto.. the one to the actuator is the one coming out the side. (assuming you have that most common sort of valve)
Old Mar 4, 2012 | 11:16 AM
rich123's Avatar
rich123
im just using a 2 way valve 1 pipe either side on the valve 1 in and 1 out with pressure hole at the bottom
Old Mar 4, 2012 | 11:17 AM
focusv8's Avatar
focusv8
That statement alone means you need serious Professional help
Put the spanners away now.
Old Mar 4, 2012 | 11:19 AM
pee vee's Avatar
pee vee
why dont you just use the amal valve?
Old Mar 4, 2012 | 11:23 AM
Smit's Avatar
Smit
The 60ft Launch King
Take the bleed valve off for god sake your asking for trouble!
Get a Amal valve with a proper jet!
Old Mar 4, 2012 | 11:29 AM
Ive got an amal valve on mine but its not plugged in. When it got mapped i got told there was no power to the valve so the amal valve has opened and messed about with.
Ive lost boost from my engine.I know my turbo is tired so im gonna change that then get it looked at.
Old Mar 4, 2012 | 11:35 AM
rich123's Avatar
rich123
yea thats why im using a valve my amal valve has died
Old Mar 4, 2012 | 11:40 AM
Whats the spec of the engine matey ie injectors chip.
Old Mar 4, 2012 | 11:45 AM
martysmartie's Avatar
martysmartie
Either as said the pipes arn't connected corretly or split etc, or the wastegate is jammed.
Martin
Old Mar 4, 2012 | 12:37 PM
rich123's Avatar
rich123
just been out thought id try the amal valve again,right its working again but still the problem of overboosting (wastegate is free,no splits in the pipes,and the pipes the right way round) got a feeling its the wirkings in the amal valve will take it apart later
Old Mar 4, 2012 | 12:53 PM
martysmartie
Unplug the electrical connector, is there any difference?
Martin
Old May 8, 2012 | 01:09 AM
TOMMY_TURBO's Avatar
TOMMY_TURBO
mine doing the same cant find the cause tho was all fine then just started doing it
Old May 8, 2012 | 01:53 PM
martysmartie
Do you have a split hose and what boost controller do you have?
Martin
Old May 8, 2012 | 09:01 PM
TOMMY_TURBO
mine only does it with amal on if i run pipe straight from compressor to actuator it runs 18psi but with amal conected it overboost to 28psi and pops was all ok at 24psi then 1day parked car up for few hours got back in and 10psi boost dv split so replaced and ever since overboost with amal connected also boost gauge aint that steady any more even at 18psi with amal bypassed
Old May 9, 2012 | 12:24 PM
martysmartie
It sounds as if the Amal isn't working, do you have the pipes on the correct unions and you don't have a constant power feed to it do you?
Martin
Old May 9, 2012 | 02:24 PM
TOMMY_TURBO
Martin
yes i do have constane feed to it is it not surposed to?
Old May 9, 2012 | 03:01 PM
James @ M Developments.'s Avatar
Check the Wastegate actuator diaphram is not leakng. if it is, nomatter how much air you pump into it, the gate will not open untill the exhaust gasses push it open.
Also try plumbing it compressor stright to actuator so you are running only spring pressure with no external control to see what effect you have.
Always check fuelling and for det while playing with boost!
Old May 9, 2012 | 05:05 PM
martysmartie
He tried this, as above, and it works!
Therefore I suspect it's something to do with the Amal.
It is supposted to have a constant feed as it's the ground that is switched, I just wondered if it's wiring etc had been messed with etc.
Martin
Old May 9, 2012 | 05:11 PM
Or the jetting. Check it has a jet in port r
Old May 9, 2012 | 05:21 PM
martysmartie
That did cross my mind as well, but don't some just remove them, is it a given that you must have a suitable size one? I don't have one in mine, so should I have really?
Martin
Old May 9, 2012 | 06:10 PM
That depends how the boost control is set up and how much air you want the valve to bleed off.
Removing the jet in port r will make the boost increase massively when the valve is open if the actuator is correctly loaded
Old May 10, 2012 | 02:31 PM
TOMMY_TURBO
on idle i believe iv got a constant earth aswell
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
landaqmabba
Sep 15, 2015 07:16 PM
